Torque Spec & gasket
Old Oct 12, 2004 | 06:21 PM
pipe's Avatar
pipe
Default Torque Spec & gasket
Is there a torque spec for installing the carrier to the batwing? I didn't see one in my service manual. Also I never have any luck using silcone to seal anything (beween batwing & carrier) could I make a gasket for it?
Old Oct 12, 2004 | 07:06 PM
CFI-EFI's Avatar
CFI-EFI
You must not have a Helms. "Differential Carrier To Cover Bolts...27-34 N-m...20-25 Ft. Lbs." Dana doesn't make a gasket. Therefore Chevy can't offer it. If you would rather have something in there, you could make one.
RACE ON!!!
Old Oct 12, 2004 | 07:21 PM
pipe's Avatar
pipe
Thanks CFI EFI I was looking in the factory service manual
Old Oct 12, 2004 | 07:31 PM
CFI-EFI's Avatar
CFI-EFI
The Helms IS the factory service manual. Helms prints them for Chevy. In my book it is listed on the last page of section, 4B.
RACE ON!!!
Old Oct 12, 2004 | 08:00 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Here's a link to the sequence AND the torque for both the 36 and 44. This also matches what is in my '95 factory manual.
http://temp.corvetteforum.net/c4/mrmojo2//danarear.jpg
Old Oct 12, 2004 | 08:40 PM
CFI-EFI's Avatar
CFI-EFI
Interesting. My book doesn't show a tightening sequence, but I would have used something similar, to achieve the same effect. The torque spec difference, by model, is interesting, too, because for either axle you have M8 bolts threaded into aluminum. Thanks for the link.
RACE ON!!!
Old Oct 13, 2004 | 02:03 AM
Corvette Kid
At some point, the size of the bolts for the control arm brackets changed from 10 to 12 mm. This is probably when the torque spec changed. I'm swapping in a 44 right now and although it's from an '85, I used the later spec. After torquing, I removed those four bolts and drilled the holes out as needed. Note that only the lower bracket bolt on each side is involved in the initial torque sequence.
Old Oct 13, 2004 | 11:00 PM
pipe's Avatar
pipe
Thanks guys for the help. The first time I installed the carrier I snapped the ears off the carrier tightening the strut rod bolts. Apperently the carrier case was different and the bolts bottomed out and broke the case. Now i'm getting the3:07s switched into my old carrier and shouldn't have a problem. Now i'll torque everything instead of just tightening away!
To Torque Spec & gasket
