TOOL LIST (So far) For Cam/Head/Intake
Old Aug 1, 2001 | 02:44 PM
scorp508's Avatar
scorp508
Ok, here is the list of tools only you guys have come up with that I will need.
This does not include things like gaskets, lubes, cleaners, wire ties, etc etc....
<UL TYPE=SQUARE><LI>16mm Line Wrench<LI>Balancer Puller/Installer<LI>Big f'in hammer (Have)<LI>Cam Install Tool<LI>Crank Snout<LI>Cutting Discs for Die Grinder (Have)<LI>Degree Wheel & Pointer<LI>Fuel Line Quick Disconnect<LI>Gear Puller<LI>Pushrod Length Checker (Have)<LI>Rubber Nipples for Fuel Lines<LI>Scribe (Have)<LI>Sockets/Wrenches (Metric & SAE)(Have)<LI>Tap Set (Have)<LI>TDC Locator<LI>Thread Chaser (Have)<LI>Timing Light (Have)<LI>Torx Bit/Socket Set (Have)
</UL>
I'm pretty sure we have a gear puller, but I know I don't have a balancer puller/installer for a SBC at my house.
What are we missing, I'm sure I forgot to put something on there.
Old Aug 1, 2001 | 02:45 PM
-=Jeff=-'s Avatar
-=Jeff=-
Bottle opener...
Old Aug 1, 2001 | 03:00 PM
Jim Martley2's Avatar
Jim Martley2
Torque wrenches? Ft./Lbs. & Inch/Lbs.
Oil pump priming tool
GOOD straight edge (to check pushrods & timing chain alignment)
Long Bolts to screw into cam to help install in block
Scotch Brite Pads (maroon colored) GREAT for cleaning gasket surfaces
By the way, a 5/8" Line wrench is the same size as a 16mm Line wrench
Old Aug 1, 2001 | 03:03 PM
Pete Pulos's Avatar
Pete Pulos
Scorp
Just a word of advice. A dumb move on my part when I updated mine, when you pull the harmonic make sure that you have the crank bolt losely on the snout. I tried to pull the harmonic with no bolt and the center piece of the puller crushed the tips of the crank's threads. This put me back a few days since I had to retap the threads. Fortunately, not much damage.
Also try to do this job during the mild months. I did mine during Jan-Mar in Wisconsin. Just had a torpedo heater in my garage. Feet were freezing and the CO probably wasnt very healthy either. But that's why I brought my dog in garage with me. I figured that the canary passing out worked for coal miners that when my Golden passed out it was time to get a beer.
Good Luck
Old Aug 1, 2001 | 03:05 PM
scorp508's Avatar
scorp508
Originally Posted by Pete Pulos:
[B
......when my Golden passed out it was time to get a beer.
[/B][/color]
But did your bring him in for one too!?? [img]http]//www.corvetteforum.cc/ubb/biggrin.gif[/img]
Old Aug 1, 2001 | 08:15 PM
Muffin's Avatar
Muffin
Now I know what my wife's dog is good for.
Scorp, have plenty of cheap paper towels and a can or two of brake cleaner. Also have some type of lint free wipes. You will need some type of assembly lube for the cam and lifters.
Old Aug 1, 2001 | 08:41 PM
FoolCrzy's Avatar
FoolCrzy
Dial indicator for degreeing the cam...
Old Aug 1, 2001 | 09:26 PM
Ray Zavorka's Avatar
Ray Zavorka
[/color]
Dog? Heck, I just have the wife help me! Grin
Ray
Old Aug 1, 2001 | 09:52 PM
HighHopes85's Avatar
HighHopes85
Hey, for the Cam install tool, the grip for big drill (the helper grip that goes into the side at a 90* angle) usually has the same thread as the front of the cam. -Matt-
To TOOL LIST (So far) For Cam/Head/Intake
