air conditioning dye test
Old Aug 1, 2001 | 10:31 PM
teacherjim's Avatar
teacherjim
My car (1994) was blowing hot air so 5-11-01 I took it in and had a dye test to see if it was leaking. T he test showed no leak so I had the air conditioner recharged. I then went on a week long trip and the air worked great. I had a water pump go out and had it replaced along with a manual fan switch. The problem is that this was several weeks ago, today I went to turn on the air and it only blew hot air. Could the above changes messed up the air? I wondered if the fan switch could be causing this. I went out and disconected the battery for 10 minutes but nothing changed except now I have a service ride control light lite up!, how do I get rid of that?. Any idea's for the air problem?
Old Aug 2, 2001 | 02:05 AM
weekendwrench's Avatar
weekendwrench
Is the compressor running when you turn the AC on? If it isn't you can put a jumper wire accross the low pressure switch to engage the clutch to see if the ac gets cold. If it does you could have a bad low pressure switch or you could have a leak and actually have low pressure. Don't run the compressor for a long time with the low pressure switch bypassed in case you are low on refrigerant. Many AC shops will use a sniffer to look for refrigerant leaks. The o rings on the back of the compressor are common leak points and the connections to the condensor are too.
Old Aug 2, 2001 | 11:20 AM
teacherjim's Avatar
teacherjim
The compressor isn't runing and the freon is gone. I must have a leak that the shop missed. Off to find a better shop to find the leak.
To air conditioning dye test
