Questions questions... [ engine ]
Old Oct 13, 2004 | 09:33 AM
devilfish's Avatar
devilfish
Default Questions questions... [ engine ]
Torque value on the knock censor to the engine block?
Can you mount the engine mounts wrong, or does it only mount in one way?
Old Oct 13, 2004 | 10:00 AM
comp's Avatar
comp
what do you have ?
Old Oct 13, 2004 | 11:16 AM
devilfish's Avatar
devilfish
Originally Posted by comp
what do you have ?
im so sorry :o
1991 6spd. Stock block. Se sign for mods..
Old Oct 13, 2004 | 11:17 AM
Steel Blue 91's Avatar
Steel Blue 91
Don't quote me (don't have the manual at work) but I think the torque is 14 ft/lbs on the knock sensor.
Can't help on the mount.
Old Oct 13, 2004 | 11:30 AM
Timmy!'s Avatar
Timmy!
That sounds about right - it's not very much.
Old Oct 13, 2004 | 12:08 PM
devilfish's Avatar
devilfish
hmm
ok...
Old Oct 13, 2004 | 12:11 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
While Steel's answer may be correct, be sure to verify it with the manual....the torque value is critical on this component if it's to function properly.
Larry
Old Oct 13, 2004 | 05:11 PM
eptaylor's Avatar
eptaylor
My 90 manual says 14 ft. lbs. (L98)
To Questions questions... [ engine ]
