LT1 Performance Mods?????
Old Oct 13, 2004 | 08:09 PM
bobhcky16's Avatar
bobhcky16
Default Upgrading Lt1 Help!!!
here is what i am thinking of doing to my car over the winter
1. lt4 hot cam kit
2. port and polish the stock heads
3. fuel pressure regulator
4. custom performance chip
5. exhaust cutouts
how does this sound so far???if not what do u think i should do instead of what. and what else would be a good performance modd
Old Oct 13, 2004 | 08:26 PM
Clemson Vette's Avatar
Clemson Vette
ummm ok heres my $.02
1. that'd be cool
2. i dont think that you bore and stroke heads, lol you can port and polish them tho. new valve train too.
3. heard it dont help much.
4. heard it dont help much at all.
5. i have these and it definately breathes better. headers are nice too. the fun factor out weights the performance improvements tho.
beware of doin mods that you havent researched. some require more in depth modifications than others. stuff like the exhaust is simple yet expensive. have fun!
Old Oct 13, 2004 | 08:35 PM
bobhcky16's Avatar
bobhcky16
Default exhaust cutouts
i have one question for the cutouts here is the website i found them on, do i need any other parts to make this work and how hard is it to install?
bobhcky16's Avatar
bobhcky16
i have one question for the cutouts here is the website i found them on, do i need any other parts to make this work and how hard is it to install?they are at the bottom of the page.http://www.customracer.com/corvette_exhaust.html
Old Oct 13, 2004 | 09:23 PM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
1. that'd be cool
1. good mod
2. even better mod.
3. not really needed
4. must have a custom chip with the heads and cam
5.noise does not = power / you would get a lot more out of a set of LT headers and aftermarket exhaust.
On the note -- Go for it!!!
Old Oct 13, 2004 | 09:48 PM
Clemson Vette
ok heres some clarification
1. a cam upgrades helps hp a good bit. tuning is a must tho. so you'll need a new burnt program thingy.
2. you can bore and stroke a block. this all together changes your engine and would require different internal parts that cost$$$ but you can make some sick power if matched up correctly.
3. same thing, no big help. not needed. waste of $$
4. this goes with the cam. if your car is stock it wont help unless your changing fan temps or speedo/ gear calibrations.
5. i know noise dont equal power, but it is loads of fun to sit at a light, have a loud stang come besides you and throw the pipe at you. then you hit a button, and romp on it. his eyes will pop out and he'll putt off scared. they do help a little. friend of mine had his honda with one cutout on it and it gave 10 whp. that's a fact. on a v tec 4 banger. so it cant hurt. but yea lt headers and 3" pipes make a big difference.
i got my cutouts from QTP. i've had two sets and consider these the best in quality. you have to fabricate a Y pipe into the exhaust somewhere and simply bolt these plates onto the end of that pipe. be careful where you mount em. gotta clear the ground and cant aim at no lines or wires or anything that'll burn.
so have some fun with the car. make it what you want. and keep these pointers in mind.
Old Oct 13, 2004 | 10:54 PM
silver & red CE's Avatar
silver & red CE
none of your upgrades will compare to a looser TC and a gear. After that, time for LT headers and a cam.
Old Oct 14, 2004 | 04:03 AM
runner140*'s Avatar
runner140*
Default Headers.....
Try long tube headers. With the Hot cam, you,ll need to breath out a little more.
Old Oct 14, 2004 | 09:41 AM
G-Racer's Avatar
G-Racer
Sounds like you are on the right track for a nice street package. Headers would be a good idea. The best real HP gain for you will be in having the heads professionally ported and a good 3 angle valve job with the valves backcut. I can help with that. Check us out www.steadfastperformance.com.
Thanks,
Greg
Old Oct 14, 2004 | 09:54 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Skip the cutouts, they are illegal at the track and on the street. In your town, I wouldn't want the neighbors complaining about loud cars, we get enough grief from them as it is.
1-3 go for it, but when it comes to the "chip", I didn't catch what year(maybe I missed it), but '94 and up you have to reprogram the PCM, if '92 or 93 you can do a chip. I don't know anyone local that does chips, but for tuning the PCM, you got the Vette Doctors in Long Island and Cartek in Garwood.
You don't want to mail order tuning, do it locally.
Old Oct 14, 2004 | 09:59 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
You didn't mention what year or make the car is, but it has been stated on here several times that gears should be the first mod addressed. The f-body guys swear to a 50hp increase on the butt dyno (it feels as though you gave it a 50hp increase) and i assume it is this way for the Corvette crowd. (this is putting 4:10's behind the 6 speed.) This is the first mod I'm doing on my 96 M6 over the winter.
I'm also doing the LT4 hot cam as well, but you need the long tube headers and a custom program to gain any real benefit from it. The exhaust cut out is fun to play with, but IMHO you are better spending the $$$ elsewhere.
an adjustable fuel pressure regulator (AFPR) is a good mod in my opinion. It allows you to 'tune' your motor to a degree. Once you add the cam, especially if you go forced induction or nitrous, I think it is a must.
I'd also go with the free mods too. There is much debate over whether these will help you or not, but they are free and no one said it hurts so I'd go for it. Here they are.
-cut air lid (add K&N for $50)
-throttle body bypass
- hollow the MAF (if applicable) Personally I'd buy a spare on Ebay and hollow that one. Then you still have the stock one should anything happen to go wrong.
All of the above can be done free if you don't add the additional parts I listed off to the side. I'd add the 160 stat and fan switch to the list as well. Good luck and happy racing!!!
Old Oct 14, 2004 | 12:43 PM
Red_Vette_93's Avatar
Red_Vette_93
Greg what's a ballpark figure to do the heads professionally ported and a good 3 angle valve job with the valves backcut.
I have a 93 with a LT1 motor.
Thanks, Jim
Old Oct 14, 2004 | 03:12 PM
bobhcky16's Avatar
bobhcky16
about the gears what size do you think i shhould get nd i drive this car everyday and its an auto.And for the headers wut brand do u think is the best i was thinkin of hooker,tpis,bbk and wut size header would i get the most power from?
Old Oct 14, 2004 | 06:17 PM
fsr402's Avatar
fsr402
St. Jude Donor '06
If you drive a lot of highway go with the 3.54's for gears but if not go with 3.73's. I have 3.73's and I love them.
Old Oct 14, 2004 | 06:42 PM
bobhcky16's Avatar
bobhcky16
the only highway miles i really do i every monday i drive about 15-20 miles there and then back,so which one would u recomend. Can u give me a good web site where i can find them pretty cheap and that comes with everything.
Old Oct 14, 2004 | 06:57 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
Thanks,
Greg
Guys I can vouch for Greg he's a stand up guy and does beautiful work. I just got my heads back from him today and they're sweet! Greg took the time to walk me through my options and has consistantly given me good advice throughout my engine project. After the "full race" competition port and polish my heads are flowing numbers that should support 525 hp.
Old Oct 14, 2004 | 07:02 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
If you're going to have someone install the gears I'd find someone and talk to them first because they might already have a good source. Correct me if I'm wrong, I think a good price installed is $800-1200? I think a set of 4.11's is going to be my next modification.
To LT1 Performance Mods?????
Old Oct 14, 2004 | 07:56 PM
fsr402's Avatar
fsr402
St. Jude Donor '06
Go with the 3.73's. I have gone 300+ miles at a time at lest 10 times this year at 80 - 100 MPH the whole way with mine. At those speeds I was running about 3000rpm or a little over.
I bought a D36 from LPE on ebay, it had the 3.07's in it and I had a local drivetrain shop do the gear swop. I paid $250 for the dif, and $400 for the gears and install with a complete rebuild.
Old Oct 14, 2004 | 10:05 PM
jpee's Avatar
jpee
I dunno if this is any help, but look at the ET's some LT1 are running, & what Mods they have, then compare it to mine..
I have never been "Inside" my motor... the only motor mods are 1.6 RR..
I still have my STOCK exhaust manifolds & cats on the car.. I did remove the mufflers only..
I went to 3.73s and a 3500 converter to run the 12.2 .. now I went back to a 2800 converter & run 12.7 still at 110 mph in "GOOD AIR"
Old Oct 15, 2004 | 08:27 AM
G-Racer's Avatar
G-Racer
Jim (Red Vette),
Porting starts at $450 for Street/Strip Poting. 3 angle valve job, setting spring height, back cut valves $325 if guides are good. Please call for more detail.
Greg Parker
Steadfast Performance
703.609.1200
