dash lights blink
Old Oct 13, 2004 | 08:27 PM
blown66's Avatar
blown66
Default dash lights blink
What is causing my 92 instrument lights and digital display to blink when I put on the brakes? Gotta be something simple.
Old Oct 13, 2004 | 09:38 PM
eptaylor's Avatar
eptaylor
Do they blink or do they get dim? Since your engine is also slowing down when you are braking a low battery needs to provide additional power to the brake lights so all other electricals have to share and will get decreased power. Battery going bad or corroded terminals?
Old Oct 13, 2004 | 10:00 PM
mikey whipreck's Avatar
mikey whipreck
what i would check...
1. battery connections
2. charging system (are your alt and battery alright?)
3. grounds
Old Oct 13, 2004 | 11:15 PM
blown66's Avatar
blown66
They dim them go back to normal. They don't stay dim. Even the radio light does it. Everything amber in color. The fan speed light or map light won't do it. The previous owner put one of those screw type disconnect connectors you see on street rods on the positive post. I'll clean all that and see what happens.
Old Oct 13, 2004 | 11:49 PM
mikey whipreck
get rid of that and see what happens
Old Oct 14, 2004 | 03:53 AM
runner140*'s Avatar
runner140*
3. grounds
I agree. Those are where you want to start. Mine did the same thing and it was battery connection. Quick fix.
To dash lights blink
