Power Window Broke
Old Oct 13, 2004 | 11:19 PM
waterboy's Avatar
waterboy
Default Power Window Broke
On my 94 coupe the drivers side window quit working. Where should I start looking to fix it? Thanks for any help!!
Old Oct 13, 2004 | 11:47 PM
bogus's Avatar
bogus
the motor, sad to say.
try slamming the door REAL HARD once or twice, if it starts to run, then the motor is more than likelt the cause. They're not noted for just quitting... they die a slow death. Kinda give you warning!
Old Oct 14, 2004 | 02:13 AM
MrRenoman's Avatar
MrRenoman
Remove the door panel and check for voltage at the motor connector. Remove the connector, use a volt meter. The voltage reverses when you go from up to down. If voltage is good, it's probably the motor. BTW, I have regulators for both sides. They're used but are good.
Art
Old Oct 14, 2004 | 09:32 PM
MrRenoman's Avatar
MrRenoman
Waterboy,
I replied to your PM.
To Power Window Broke
