If I take off the throttle body, do I just need a new TB to Plenum gasket ?
I see there's also a 'throttlebody cover and base gasket' listed in the catalogues but I can't see it in the manual - what is it?
I'm planning to get my worn throttle re-bushed, here in Australia, and I'd like to replace the spindle, does anyone know where I can a new one of those?
The throttle body cover is the piece on top of the TB that can come off(six bolts, I think). If the rebushing requires the top to be taken off then you need both gaskets.
There is also a gasket that separates the TB from the canal that the coolant passes thru on the bottom of the TB.That's if you didn't do the TB Bypass.
