Calling all L98 383 owners HELP!
He noticed that the damper they are using has the pulley actually on the back of the damper. And in looking at the additional pictures that they have on-site for this engine. http://www.sallee-chevrolet.com/Chev...eeZZ450HP.html It definitely looks like that is the case.
We have made the assumption that that damper isn't gonna work. Since this sites search function is not working. I can't do any searches for 383s. Or for anyone on this forum that may be using a zz450 crate eng.
So how about it guys. Anyone out there actually using this engine? If so how well does it run? And how did you get around the damper problem?
For all L-98 owners. I'm not sure just how much the front crossmember position and stuff might have changed from year to year. For all I know I may need someone with an '89 and an '89 only to tell me what damper they are using on their 383's.
Thanks So Much In Advance Guys
Gary
As long as the balancer will accept the bolt on pully (it should) I think it will work. my stock 86 motor had a large balancer, 8 inch dia I think. it may be close to the frame with that built in pully on it.
one thing I know is those valve covers will hit the wiper motor. I had to cut/weld one of mine to clear.
see if you can find out what diameter the balancer is (actual dia)..
RJ
Drop me a note if you interested. ( It cost $389 new...a few years back...I'll let got of it for $150 )
The problem is that we know that the serpentien belt will not line up with the damper that is on there. As the one that they have on their engine now actually has the pulley on the back versus the front of the damper where it belongs.
Now the problem is that when and if we find a damper that will work. Then the guy at Sallee Chevrolet will oder it. And upon getting the part in he will have to install it and balance it as an assembly. Prior to shipping the engine
And let me remind you again that we are talking about a 400ci damper here as this is going on a 377. So BBA I'm sorry but no can do.
Thanks again guys,
Gary
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:[/color]<HR><font face="Verdana, Arial" size="2">
[/color][/QUOTE]
It is a smallblock externally balanced SFI approved Fluidamper.
Yes, it is a 400CI damper.
I only hope that Speed-O-Motive has actually sold enough of those things where than can tell me with 100% confidence that yes this will in fact work in an '89 Corvette.
BBA, I hope you didn't take that the wrong way. I didn't mean to say for a second that I thought that you didn't know the difference. I was simply trying to remind other people that might come along what the true problem at hand was i.e. we need a 400ci damper that will fit an '89 Corvette.
HiTech5, Yes it is externally balanced. If you look at the site you will see the flexplate included. Yes as this was originallly based on a ZZ4 engine. I was already aware of the problems that the Vette community was having with attempting to install the ZZ4.
Like finding out tha they needed to retain from their old engines there old oil pan, timing covers, water pumps, distributers, and dampers.
That's why I said that we had worked through those issues already. And this was the sole remaining problem. For what it's worth he said that the oil pan, and timing cover on this engine will work.
Actually the problem that people were having with the timing cover on the ZZ4 was three fold. First off it was plastic.
Secondly it would not allow you to install the water pump. Some people decided to take shortcuts. And rather than going to the hassle of yanking it. And replacing it with their old ones. Some people chose to simply grind down the offending bolt heads enough to clear the waterpump.
Later these guys were wondering why their engines were running like crap. Only to find that because they had used there old balancers. They had no choice because the new ones were to long. But they used the old balncers with the new timing cover. And thus had thrown their timing off to god knows where. Using the timing mark on the new timing cover.
Now in this case trust me everything will have to match up. Because we will be using a new 400ci damper and the new timing cover made for it. The guy yesterday assured me that it will work. But I will ask him again.
In this case the oil pan will work, and the damper and timing cover are going to have to work. Once we can find the correct damper anyway. The waterpump and distributer must be carried over.
Ski_dwn_it, I'm not sure what your asking. If your asking whether or not all of your instruments will work or not yes they will. That is why you have to use the old ditributer as a matter of fact. Because their replacement distributer lacks a tach drive. You will also pull the old or install new sensors, o2, Knock retard, etc.
Everyting will work. You simply pull the old manifold with everything on it and plant it in the new engine. That's the one thing that I hadn't mentioned untill this point. Since it is standard fair to do that when instaling a longblock crate engine.
Thanks Again Guys,
Gary
Yesterday the guy was sayin that it had the puley behind the damper. And that I was going to have to come here and find out what everyone with an '89 was using. And call him back with the info.
The guy I jut talked to today said. '89 Corvette.. "Yeh it uses a 7" damper. We will swap out the 8" for the 7". Not a problem." Man I was in and out of that conversation in 30 sec flat.
Thanks Guys!
Gary
-Heads".
These heads require special intake manifolds, and WILL NOT WORK with TPI systems, the S/R or the MiniRam! The only place talking about having special intakes cast for the FB-Heads to fit TPI's was Scoggin Dickey Chevrolet, and I think they still haven't released them to the public?
I for one wouldn't touch the Miniram with a 10' pole. But hey that's just me. So at any rate I'm going to be using Edelbrock's Performer Centerbolt Corvette heads instead.
Sallee said no sweat you could use any GM, World Products, or Edelbrock head that you want.
Thanks Bunches!
Gary
I have a Pioneer Inc P/N 872001, 6" dia, external balance damper.
Speed-O-Motive has been around since '47, and they have a lot of experience building strokers. Hopefully my engine will be installed and running by the end of the month. I'll post the results!
http://www.speedomotive.com
Hope This Helps
Gary
