Chime
Old Oct 14, 2004 | 12:02 PM
C4SMAJ's Avatar
C4SMAJ
Default Chime
the chime that goes off to let you know if you left the lights on or the key in the ignition has stopped working on my 96....can someone tell me where that thing is located so I can pull it and get a new one....thanks.........
Old Oct 14, 2004 | 12:09 PM
edsalinas's Avatar
edsalinas
St. Jude Contributor
It's a known problem with the C4's. It's a PITA to get to, inside the center of the dash, behind the D.I.C. there's a small circuit board where the chim device is soldered to.
Good luck...
Old Oct 14, 2004 | 12:33 PM
C4SMAJ's Avatar
C4SMAJ
thanks much....sounds like its something Ill just live without...
Old Oct 14, 2004 | 02:27 PM
edsalinas's Avatar
edsalinas
I do........
Old Oct 15, 2004 | 02:57 AM
BlackbirdZ07's Avatar
BlackbirdZ07
Does anyone know if you can get to it by simply removing the DIC or do you have to remove the top dash pad?
Old Oct 15, 2004 | 05:07 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Even on an '84.
To Chime
