G-tech on my 84
Old Oct 16, 2004 | 02:41 AM
MY84REDC4's Avatar
MY84REDC4
Default G-tech on my 84
ok I took the car out tonight with a G-Tech. I did a
15.58 @ 89
and
15.56 @ 90
with my 200lbs roomate in the car with me. I dont know how accurate the G-Tech is but thats what it said.
has anyone else used a G-Tech and also gone to the track and found out about how accurate it is?
I also spun for almost a second the road wasnt all that great so with my BFG Drag radials on at the track I think I would do better.
Old Oct 16, 2004 | 05:09 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
It's all in how you set it up(perfectly level,plumb etc).
I tested it at the track and was off by a few tenths and several MPH, butteh G-Tech will always show a higher MPH due to the fact that it gives terminal speed rather than trap speed.
To use as a tuning tool to gauge improvement, it's not bad, but I wouldn't rely on it for accurate 1/4 mile times.
I haven't tried the newer model which I hear is supposed to be more accurate.
Old Oct 16, 2004 | 09:30 AM
fsr402's Avatar
fsr402
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
I tried one a week or so ago on mine. No N20 used and I spun thru 1st and half way thru 2nd and she read 14.2 @ 105mph. The last time I went to the strip I ran 13.8's @ like 97mph with no spin and no N20. So I would say that the times are close and the speed is a little high (like Mojo said)
Old Oct 16, 2004 | 11:53 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
I ran mine at the track, but only once... it was way to distracting to set up and stilll get a good start.
The Gtech was slow by .22 sec and high by 4.5 mph. I've used it a bunch of times though on the backroads.
Old Oct 16, 2004 | 02:51 PM
CFI-EFI's Avatar
CFI-EFI
The ETs from the G-Tech will be SLIGHTLY slow, depending on how you stage at the strip. The G-Tech starts timing when it senses movement. That is consistent with a deep stage. In a shallow stage, you get a "running start" at the starting line clocks. Eliminate your wheel spin. Your G-Tech ETs are close to what you should expect.
RACE ON!!!
Old Oct 16, 2004 | 03:04 PM
VinDogg003's Avatar
VinDogg003
im thinkin about buying one off Ebay, all it plugs into is the cigerette lighter and thats that ?
Old Oct 16, 2004 | 09:15 PM
MY84REDC4's Avatar
MY84REDC4
yeah it plugs right into the lighter spot. you just have to stick it to your window and make sure it is leval and straight.
To G-tech on my 84
