How do I remove the main driveshaft?
Old Oct 16, 2004 | 01:44 PM
Sawbone's Avatar
Sawbone
Default How do I remove the main driveshaft?
I already dropped the exhaust and am wondering how to get out the main driveshaft from this point. There are 2 straps that hold the rear u-joint in place. Once I remove those, I will need room to slide the shaft towards the transmission to break the rear u-joint free from its mount. Does the shaft have room to move towards the tranny or will I need to remove the brace that attaches the transmission to the differential?
Old Oct 16, 2004 | 02:02 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I just had mine out, but I was also swapping differentials. But I THINK if you unbolt the C-beam, you can wiggle it out. Make sure and support the rear of the trans.
Old Oct 16, 2004 | 02:04 PM
bogus's Avatar
bogus
The drive shaft and the c-beam kinda come out together.
Support the rear of the tranny, and slide the c-beam forward, letting it drop out, then the drive shaft can be loosend and removed.
Old Oct 16, 2004 | 02:11 PM
Corvette Kid
There ya' go! Also, to answer the other part of your question, which I missed before, the driveshaft will slide forward into the trans and give you plenty of forward movement to drop it out of the pinion yoke.
Old Oct 16, 2004 | 02:21 PM
STL94LT1's Avatar
STL94LT1
I don't even remember how I did it. But, I removed the driveshaft with the exhaust and C-beam intact.
Old Oct 16, 2004 | 05:11 PM
Sawbone's Avatar
Sawbone
Thanks for the info Once I unbolted the straps the driveshaft slid forward and came right out without having to touch the c-beam.
Old Oct 16, 2004 | 10:41 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Man you must be good, I'd pay to see that.
To How do I remove the main driveshaft?
