changing fuel reg??
Old Oct 17, 2004 | 05:51 PM
6spd's Avatar
6spd
Default changing fuel reg??
i bought a holley fuel reg and is there an easy way to change this i mean can i just take off one runner the drivers side and the plenum??
Old Oct 17, 2004 | 06:35 PM
Steel Blue 91's Avatar
Steel Blue 91
You don't need to pull the runners. Just the plenum.
Old Oct 17, 2004 | 06:46 PM
6spd's Avatar
6spd
when i put my my first reg on i did take it apart but the plenum is tight when i try to slip it in. i will have to loosen the runners from the manifold???
Old Oct 17, 2004 | 06:49 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
If you've had the plenum off once, it will be much easier this time and to put back too.
To simplify plenum installation, set it in and hand start a few bolts on one side. Then lean on it till you can hand start some bolts on the other side. The trick is to get all bolts to turn easily by hand till maybe half way in, then there is no danger of cross threading.
To changing fuel reg??
