Battery Advice Needed
Old Oct 17, 2004 | 09:42 PM
Cruz 86's Avatar
Cruz 86
Default Battery Advice Needed
I realize this is a wee bit off topic but I know some of you guys will have the answers. I'm restoring an old vega drag car and it has two large batteries with threaded posts (probably marine batteries) mounted in back. I will not be running a generator or alternator so I'll be charging the batteries in between rounds. I'm thinking of using marine batteries so they will have the same kind of posts. Would it also be a good idea to go with deep cycle marine batteries since I'll be doing so much recharging? If a deep cycle battery is rated at enough cold cranking amps will it start the car o.k.? I know deep cycles are for running accessories, pumps and other long slow drains, but are they also good for starting engines? Any and all opinions welcome. Thanks!
Old Oct 18, 2004 | 09:38 PM
quiksilver458's Avatar
quiksilver458
cant help you there... bump to the top tho
Old Oct 18, 2004 | 10:02 PM
BLK/BLK'93's Avatar
BLK/BLK'93
The best battery to use is a multi purpose marine battery. They have the thread mount you are looking for, and also have the power to run the starter. You can find them at Auto Parts stores in the marine section. They will say for dual purpose. Just the deep cycle will not provide enough power to run the starter.
To Battery Advice Needed
