Will Z06 wheels fit a C4?
Old Oct 18, 2004 | 11:06 PM
jedrake72's Avatar
jedrake72
Default Will Z06 wheels fit a C4?
I have seen a lot of wheels that resemble Z06 wheels on C4s but they end up being 17X9.5 all around. Will the 18X10.5's fit on the rear of a C4? Why don't we see more of this?
Old Oct 18, 2004 | 11:09 PM
vader86's Avatar
vader86
They do not fit without a spacer plate.
Old Oct 18, 2004 | 11:27 PM
chaos on wheels's Avatar
chaos on wheels
I've got 18x10.5 all around on my '90. With over a degree of negative camber on the rear, the tire would touch the inner fender liner on big bumps. With about 0.75 degrees, it fits fine!
Old Oct 18, 2004 | 11:30 PM
MYCoupe's Avatar
MYCoupe
I've got stock sized Z06 wheels on my car and they fit w/o any problems. You will only need spacers if trying to mount them onto a 84-87.
Old Oct 19, 2004 | 12:52 AM
jedrake72's Avatar
jedrake72
So on a 96, no problems if I keep the camber under 1 degree? That's with 295s?
Old Oct 19, 2004 | 07:54 PM
MYCoupe's Avatar
MYCoupe
I don't know what my camber is set to as I've never had the car aligned, but I get no rubbing with 295s out back. You can always add a 1/4" spacer if you get some light rubbing.
To Will Z06 wheels fit a C4?
