Delteq Install Pictures
Old Oct 19, 2004 | 04:53 PM
maldo's Avatar
maldo
Default Delteq Install Pictures
Hi Guys,
Just wanted to show you our lastest install and using our new powered-coated brackets (I made a house call for (Bruce Ensworth’s who has a beautiful 95 convertible z28 (http://www.rivercityf-bodies.com/ (he is our local f-body Club President)
We did not use the colored wires because we will show that later with a header install…. These pictures will be updated on my web site with details to go over the install…. I just wanted to get the pictures out to show how easy these units install…
http://www.ofoto.com/BrowsePhotos.js...1&sort_order=0
THX Jim
Thank You,
Jim Maldonado
Elitesparkplugs.com
Featuring the Opti-Direct ignition system from “Delteq”
Authorized Delteq Dealer/Wholesaler for Opti-Direct Ignition Systems
Old Oct 19, 2004 | 05:17 PM
Steel Blue 91's Avatar
Steel Blue 91
Link not working.
Old Oct 19, 2004 | 05:31 PM
TankerVette's Avatar
TankerVette
hopefully easier to install then it is to use the link...
Old Oct 19, 2004 | 05:33 PM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Originally Posted by Steel Blue 91
Link not working.
Old Oct 19, 2004 | 06:38 PM
Great White North's Avatar
Great White North
Originally Posted by VictorRussell'92
Old Oct 20, 2004 | 08:47 AM
maldo's Avatar
maldo
Sorry try this one
Thank You,
Jim Maldonado
Elitesparkplugs.com
Old Oct 20, 2004 | 09:13 AM
mitchcole's Avatar
mitchcole
Why did you run the wires back around the front of the motor instead of straight over the side?
Old Oct 20, 2004 | 09:15 AM
comp's Avatar
comp
on link
Old Oct 20, 2004 | 09:35 AM
HJV11's Avatar
HJV11
I read that you have another set of wires to go on later? What wires did you go with? I just ordered my Delteq without wires because I am mounting it in a different location and will cut to fit my own wires. I assume the coils accept HEI boots and am looking for wire recommendations.
Old Oct 20, 2004 | 10:25 AM
maldo's Avatar
maldo
Hi this car had stock exhaust manifolds. You can not drop them down the side becasue the wires will get burnt.. With f-bodys with stock manifolds you have to run the wires under the manifolds
Thx Jim
Old Oct 20, 2004 | 10:32 AM
VR'92's Avatar
VR'92
St. Jude Donor '03
Cool, thanks for the pics.
Old Oct 20, 2004 | 10:38 AM
maldo's Avatar
maldo
Hi were you locating the unit? (Also did you buy from me?)
I have pre-made 8mm (plain black) kits for the vettes if you mount it on the valve cover.
Why go through all the trouble to cut and fit your wires when we can do it for you … I can make any length wire you want in 7, 8 or 9mm (I have 10mm but it's a pure racing wires with a copper core not good for daily use) these wires come in many different colors also and come with a life time warrant from cracking arching etc also you get a 1200 degree protective sleeve on the whole wire.
Call or email me for prices.
Thank You,
Jim Maldonado
Elitesparkplugs.com
Old Oct 20, 2004 | 10:56 AM
SLOWRIDE's Avatar
SLOWRIDE
Old Oct 20, 2004 | 11:20 AM
HJV11's Avatar
HJV11
I am locating it dead center behind the intake. I was steered to HP Works (I bet due to my location SE VA) by Delteq.
Because it is hard for you to accurately cut to fit wires to clear a 5" down pipe next to the valve cover.
Old Oct 20, 2004 | 02:56 PM
maldo's Avatar
maldo
Because it is hard for you to accurately cut to fit wires to clear a 5" down pipe next to the valve cover. [/QUOTE]
True if you What a set of cut to fit i can also provide that to you ... if you like...
Give me a buzz or email me if Interested.
Thx Jim
Thank You,
Jim Maldonado
Elitesparkplugs.com
Old Oct 20, 2004 | 06:11 PM
HJV11's Avatar
HJV11
Sound good Jim.
What colors do you stock, what brand wires are they and whats the price for a cut to fit set?
To Delteq Install Pictures
