Corsa's on the way.......
Old Oct 19, 2004 | 10:27 PM
BLK/BLK'93's Avatar
BLK/BLK'93
Default Corsa's on the way.......
Just ordered a new cat back system from Corsa.
I have read that some have gutted their cats and improved sound and performance. Has anyone gutted their cats wth a Corsa system? Can I gut the cats without removing them from the car? If so, what is the method for gutting on the car?
Old Oct 19, 2004 | 10:56 PM
mitchcole's Avatar
mitchcole
Those are expensive cats to hog out like that... I'd just have new head pipes fabbed up. Keep the cats or sell them on ebay. You'll have tons more space under the motor too.
Oh hell - just get some longtubes...
Old Oct 19, 2004 | 10:59 PM
mikey whipreck's Avatar
mikey whipreck
You'll probably have to take the cats off to gut them... I'm not sure how you'd get all the material out with them still on the car....
Old Oct 19, 2004 | 11:36 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
The LT1 cats flow so well, there's probably not 5 hp to be gained on the average mildly modded LT1. Eliminating the resonator would probably gain you more than trashing your cats and help keep the air cleaner.
Old Oct 20, 2004 | 08:45 AM
BLK/BLK'93's Avatar
BLK/BLK'93
I was thinking about long tubes....
Will they bolt up directly to the Corsa Cat Back system? If not does someone sell adapters tomake them bolt up. Thirdly, Does someone have a long tube part number which works well with 93 LT1?
Old Oct 20, 2004 | 08:54 AM
LT1Vetteguy78's Avatar
LT1Vetteguy78
You ordered them directly from Corsa? aren't they like over $1k from Corsa.com? Why didn't you go the Mid America and get them for $840 shipped?
Old Oct 20, 2004 | 08:57 AM
Lone Ranger's Avatar
Lone Ranger
Unless you live rural, I wouldn't do anything that might cause the car to fail an emissions test. Emissions testing is going to become a LOT more widespread accross the USA in the next 5 yrs. As a measure of the flow rate of the stock cats, the high-flow Random Technology brand bullet cats only flow about 10% higher than the stockers.
There was a group purchase on some brand of long tubes for LT1 posted on the forum just last week I think, can't remember brand but I thought I read where they mentioned fitting up to Corsa catback system with a minor alteration.
Old Oct 20, 2004 | 09:04 AM
Sawbone's Avatar
Sawbone
If you plan on installing the Corsa yourself, the instructions say to re-use the 3 factory studs/bolts on the catalytic converter. Most likely these parts are shot and will need to be replaced so plan on getting an extra set before the install.
Old Oct 20, 2004 | 09:17 AM
comp's Avatar
comp
new hardware
Old Oct 20, 2004 | 09:48 AM
BLK/BLK'93's Avatar
BLK/BLK'93
Actually I did order from Mid America, and got them delivered for $730 with shipping. Attended a vette rally in Columbus Ohio, and Mid America was handing out catalogs and a key code for 10% off anything in the catalog.
Off to buy new hardware for the cats....
Old Oct 20, 2004 | 02:37 PM
Perfusion's Avatar
Perfusion
Exotic Muscle LT headers will work with RT cats and a Corsa catback - no cutting required. The RT cats come from EM prewelded in pipes that go between the header collectors and the Corsa. Beautiful setup - it's what I have, and I'm very happy with the sound and performance!
Old Oct 20, 2004 | 03:07 PM
Ghostpilot's Avatar
Ghostpilot
Old Oct 20, 2004 | 07:37 PM
BLK/BLK'93's Avatar
BLK/BLK'93
Ok, I finally got the old system out. The two nuts came off the converter, but the bolt broke in half. I tried every tool in my shop to get the bolt out of the cat, but nothing worked. I finally ruined 12 drill bits drilling the bolt out of the cat. What a nightmare.
I am seriously considering installing long tubes. Does anyone have any long tubes which will fit with the Corsa's. I live in Ohio and we do not have emissions testing, and being a 93 there is no O2 sensor after the cats.
Can I use headers, and leave the cats off? Or is there a header system which bolts onto the cats?
Old Oct 20, 2004 | 07:47 PM
bogus's Avatar
bogus
don't ditch the cats, dude... the power gain ain't worth the emissions spent.
Old Oct 20, 2004 | 07:55 PM
BLK/BLK'93's Avatar
BLK/BLK'93
Which headers can I use with the cats? I guess this would be the easiest way. The cats only have 30K on them. They look very clean inside.
Old Oct 20, 2004 | 07:57 PM
odysseysteve's Avatar
odysseysteve
I suggest you re-tighten all of the connections after about 1000 miles or so. They will loosen up.
Old Oct 20, 2004 | 09:01 PM
Mo_Bandy's Avatar
Mo_Bandy
Enjoy your corsa's i love em...
Mo
Old Oct 20, 2004 | 09:17 PM
robtx's Avatar
robtx
You can't use the orig. cats with long tube headers they are to big, if you go with shorty headers then you can.
Dynatech makes a nice cat. in a couple different sizes to fit long tube header, but you need a small amount of custom work not expensive though.
http://www.secureperformanceorder.co...e/powercat.cfm
To Corsa's on the way.......
