CAGS relay connector, which one is it?
In my 92 I see two relays bolted to the wheelwell just to the drivers side of the master cylinder fluid reservoir. But the connector is nothing like the dummy plugs.
Now there are a couple two wire connectors in the area that look like the dummy plugs. But the wire colors do not match the post I saw describing it.
The service manual doesn't describe the location of this wiring harness connector as far as I can find in it.
Can anyone describe the correct wire assembly to disconnect?
Jay 92 LT!
the CAGS relay is located on the backside of the driverside front wheelwell.
four wires - Pink/Black DarkGreen DarkBlue DarkGreen/White
might be the same for '92 (yes? no?)
the "replacement connector" commonly mentioned is actually a 'dummy' that breaks the circuit directly at the CAGS Solenoid, located at the transmission. it's main function is to keep the open connector clean (besides breaking the circuit).
i chose to disconnect the relay instead because it defeats both the CAGS Solenoid and the CAGS Relay.
the "replacement connector" leaves the relay in the circuit, so it's always 'working'.
free.
quick.
only have to bend over instead of getting on your knees.
paul
[B
free.
quick.
paul [img]http]//www.corvetteforum.net/c4/slev89/gif/emblem.gif[/img] [/B][/color]
Thanks for clearing that up for me! There are two relays there. I wonder what the other one does....
Jay
92 LT1
I believe the other relay is the Primary Coolant Fan Relay - four wires - DarkBlue DarkGreen/White Red(thick) Red/Black(thick)
(1989 anyhoo) [/color]
Jay 92 LT1
