LT4 double roller chain
Old Oct 21, 2004 | 12:42 PM
spinedoc's Avatar
spinedoc
Default LT4 double roller chain
Does anyone make a double roller chain for an LT4 you can use with a stock water pump, not electric?
Old Oct 21, 2004 | 02:17 PM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
I asked my engine builder about this yesterday - I told him I wanted a Cloyes double roller put on my LT1 and he informed me it wasn't possible. I noticed a couple guys on the forum had them in their signatures but I guess they must have done the electric water pump conversion. I really hope I don't run into trouble with my timing chain because I'll be running the LT4 Hot Cam.
Old Oct 21, 2004 | 06:01 PM
96GS#007's Avatar
96GS#007
The other issue with the '96 LT1 & LT4 is the crankshaft position sensor reluctor ring that is sandwiched between the hub and the crankshaft timing chain gear.
Old Oct 21, 2004 | 07:52 PM
FD2BLK's Avatar
FD2BLK
With using the stock W/P you must use an LT1/4 timing set. Cloyes makes a couple but none are double rollers. With the LT4 even if you went to an electric pump it would still be a problem because of the CPS as GS96 stated. I have seen it done on a LT4 but it took a bit of machining to get the DR to work with the CPS. For a normal LT1 as long as you go with an electric W/P is a straight bolt in item
Old Oct 21, 2004 | 07:58 PM
LT4BUD's Avatar
LT4BUD
I just removed the reluctor ring and PCMforless reprogrammed the computer....no machining required with this approach.....then used Cloyes Double roller & Meziere HD electric water pump....
Old Oct 21, 2004 | 08:53 PM
ddr698's Avatar
ddr698
St. Jude Donor '09
Thats almost what i have done. I switched to an OBDI computer programmed by PCMForless and an electric water pump. This eliminates the need for the CPS.
Old Oct 21, 2004 | 10:23 PM
SouthernSon's Avatar
SouthernSon
This is not in regards to a double chain but there is an extreme duty chain that works for the stock LT4.
To LT4 double roller chain
