Oil Pan Gasket Reusable?
Old Oct 21, 2004 | 05:27 PM
white94vette's Avatar
white94vette
Default Oil Pan Gasket Reusable?
Ladies and Gents, After looking over the archives, I will ask a more specific question. Does anyone know if the 94 LT1 Oil Pan Gasket is Reusable? I have a front timing cover leak (I think) and it seems that to replace it, you should lower down the oil pan a bit to facilitate in the installation. I have read its possible to do that w/o lowering the pan, but its tough.
I would just change the oil pan gasket too, but since its not leaking, why go through the trouble.
Old Oct 21, 2004 | 05:28 PM
Z-07 freak's Avatar
Z-07 freak
From: Why are there squished peanut butter cups in my underware?
Never reuse gaskets.
Old Oct 21, 2004 | 05:48 PM
John Robinson's Avatar
John Robinson
Default Trading Leaks
If you break the seal on the pan gasket you will end up with a pan leak even if you fix the timeing cover leak. Go ahead be a big spender and buy a pan gasket Besides if you have gone to the trouble to remove the timeing cover and loosen the pan you might as well finish the job
Old Oct 21, 2004 | 05:56 PM
96GS#007's Avatar
96GS#007
It's VERY unusual for the timing chain cover to block gasket to leak. Nearly always the oil leak is originating from one of the following locations:
Front of the intake manifold (the RTV used to seal each end of the intake to the block fails over time)
Water pump driveshaft seal (located in the timing chain cover)
Optispark seal (located in the timing chain cover)
Crankshaft front seal (located in the timing chain cover)
None of the above leak locations require you to remove the timing chain cover as all can be R&R'd with it bolted in place.
If you still feel the need to remove the timing cover, then yes, the oil pan gasket should be replaced as well.
Old Oct 21, 2004 | 06:13 PM
James94LT1's Avatar
James94LT1
Its Probably not the cover gasket itself.
Also When I did my head/cam swap I had my cam a tooth off so I had to tear it all apart again and I re used my oil pan gasket cause I thought it would be fine since it only had a few hours on it. Wrong, I have a oil leak from a few spots of the pan now!
Old Oct 22, 2004 | 04:39 AM
SLOWRIDE's Avatar
SLOWRIDE
Replace it.
Old Oct 22, 2004 | 05:32 AM
runner140*'s Avatar
runner140*
Default Never reuse an oil ban gasket...
This is a cheap item and should not be reused. You are asking for a leak sometime down the road if you do. Clean the entire area, and change the gasket. Just my .02.
Old Oct 22, 2004 | 06:32 AM
Tom Piper's Avatar
Tom Piper
A highly respected GM mechanic told me the pan gaskets on a LT1 are reusable.
I had my pan off twice, I reused it once and it didn't leak.
But, if you aren't going to sleep at night, it isn't worth the few dollars it takes to replace it.
Tom Piper
Old Oct 22, 2004 | 07:45 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Get a Fel-Pro gasket and copper RTV silicone and never sweat that leak again!
To Oil Pan Gasket Reusable?
