Headlight rotates up & close while driving.
Old Jul 19, 2001 | 12:34 PM
kola's Avatar
kola
While driving with my headlights on, the driver's side headlight will close, open, close, etc. The light is turning off when it closes.
Also the passenger side light is a little hesitant to go back down when I turn them off.
Any ideas what my problems may be and how to fix them.
Old Jul 19, 2001 | 02:26 PM
jaa1992's Avatar
jaa1992
From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
This applies to most of the headlight assemblies in our C4s. Older C4 have gears that wear out, newer C4 have bushings that wear out.
If your headlight system has gears (before 87 I think) get metal replacement gears. Otherwise buy the bushing kits. Get enough to repair both sides!
I just did this on the drivers side on the 88. It was not too dificult.
Old Jul 24, 2001 | 12:50 AM
JOHNL's Avatar
JOHNL
Kola Did You get this problem resolved? Mine is doing some thing.
Old Jul 24, 2001 | 12:56 PM
notbob's Avatar
notbob
I'll join that list ;P
What site can I order the kits from?
Mine keep getting worse everytime I use them ;P
Now I stop to make sure they go up all the way.
Old Jul 24, 2001 | 01:10 PM
JOHNL's Avatar
JOHNL
It was the Headlight Actuator Relay That was causing this problem for on My '84. Kola You may want to try switching the plug's in Your relay's (In front of the left wheel well) To see if it's Your relay.
Old Jul 24, 2001 | 06:29 PM
notbob's Avatar
notbob
Also try some WD-40, worked wonders for me
Problem wasn't the motors, was just stiff as hell, so toss some wd-40 on er and it's all good
Old Jul 24, 2001 | 06:35 PM
scorp508's Avatar
scorp508
Originally Posted by jaa1988:
[B
If your headlight system has gears (before 87 I think) [/B][/color]
'87 has the gears, new headlight system came in 1988. [img]http]//www.corvetteforum.cc/ubb/smile.gif[/img]
To Headlight rotates up & close while driving.
