1985 Dies right after startup
Old Oct 22, 2004 | 03:13 PM
ThermalJay's Avatar
ThermalJay
2nd Gear
Default 1985 Dies right after startup
I have had my 1985 for 2 years now and i am always coming across problems that baffle me. I was hoping someone could troubleshoot a problem i am having.
Got in the car last weekend and turned the key to start the car. The car has always fired up really quick and this time was no different. The cars starts and idles really well for about 2 to 3 seconds and then just putters out. I am thinking it may be something electrical or computer related.. only because it seems to stall when the idle kicks down after intial start-up. If it was a fuel pressure problem or fuel pump related wouldn't the car run crappy all the time if it even started...Any ideas?
Old Oct 22, 2004 | 03:31 PM
Draven's Avatar
Draven
St. Jude Donor '14
Sounds like your IAC (idle air control) is on its way out. Its the small protruding piece off the bottom of the throttle body. I bought a new one to be replaced this winter. When mine went on the fritz, I gave it a few taps with a rubber mallet, has worked since. Thats not really a fix, but an indicator that the IAC is your problem.
-Joe
Old Oct 22, 2004 | 03:36 PM
rick lambert's Avatar
rick lambert
When was the last time you replaced your fuel filter?
Old Oct 22, 2004 | 03:43 PM
danno85's Avatar
danno85
The other possibility is that there is an oil pressure switch in the top of the block behind the distributor that, when closed, completes the circuit that supplies voltage to the fuel pump. What happens is when you turn the key on the fuel pump is energized for 2-4 seconds in order to pressurize the fuel rails which allows the engine to start. But then oil pressure is needed to close that switch in order to keep the fuel pump running after that. The switch could be bad, or the electrical connection is loose or got knocked off. I believe it has two large orange wires running to it.
Dan
To 1985 Dies right after startup
