93 power window failing
Old Oct 22, 2004 | 03:14 PM
sp802's Avatar
sp802
Default 93 power window failing
I have to slam my door to get the window to operate. I don't know if it is a loose wire or the motor is giving out. How do you remove the door panel without wrecking it? Is the motor hard to get at and replace?
Old Oct 22, 2004 | 05:04 PM
mikey whipreck's Avatar
mikey whipreck
that sounds electrical.... bad ground or a bad connection...
you wouldn't have to remove the motor, but to get to the wiring, you'll probably have to remove the door's interior...
I believe there is a tech tip for this... have you looked?
