91 dash problem - no codes - ecm replaced
I have replaced the ECM and no change. When driving it the digits change but are not readable and the range and fuel gauge come and go.
I used a Tech2 (borrowed from my car engineer neighbors work) scan tool and it is showing no codes. However it seemed to lose connection to the ecm a couple of times a minute.
A couple of questions.. Does anyone know where the grounds that might effect this are located? Even using the factory manual I am not sure where the CCM is under the dash? is it behind the radio. Anyone ever replace a CCM?
Any help would be greatly appreciated..
To get to the CCM you will have to remove the covers under the steering column. Then remove the carpet on the tunnel on the drivers side. The CCM is located behind the radio, but you can't get to it thru there, it has to come out from under the drivers dash area even though it helped me to remove the radio so I could see it. If I remember, there is a cover that the CCM is mounted to that you remove to pull the unit out. It comes out from behind the radio towards the drivers side leg area.
Once I got it out I unplugged all the connectors to it, cleaned them with contact cleaner, reconnected them an the problem was solved. Just take your time, it is very tight in there.
Hopes this helps.
Thans for offer to scan the manual but I do have a copy of the factory service manual and what you guys are saying makes sense looking at it again. I will let you know how it turns out
