Replacement Battery
Old Jul 20, 2001 | 06:13 PM
Tom Mieczkowski's Avatar
Tom Mieczkowski
Need to replace my battery. I still have the original in the car (1996 Collector Edition LT4). Any suggestions or experience on the right battery, right fit, etc.?
Any special tips on the removal and installation process?
Any suggestions or observations would be appreciated!
Thanks.
Old Jul 20, 2001 | 06:45 PM
Fang S-289's Avatar
Fang S-289
I have derived excellent service from my AcDelco Professional battery. Model 75-6YR fits perfectly.
To replace the battery-Disconnect the neg. terminal, Remove the 3 bolts along the rear edge of the left front wheel well, Remove the bolt at the upper rear corner of the fender panel, remove the bolt at the lower rear corner of the fender panel, Remove the panel & the battery. Only takes a few minutes. Reverse steps to install. Make sure that the fender panel is correctly aligned with the door. If the door rubs the panel, realign it and retighten the bolts.
Hope this helps.
Old Jul 22, 2001 | 09:10 PM
Togo's Avatar
Togo
Batteries, batteries, batteries!
i have had the best luck with Optima, and would therefore recommend NOTHING else. Optima part number 75/35-925, model 8022-091 is the perfect fit for my '85
why do i love optime....because they are SEALED gel cell batteries that never leak, NEVER EVER CORRODE and we all know that is a problem! and not to mention, the one i have in myu full size chevy truck is 5+ years old serving that full sentence in the hot arizona desert!
trust me when i tell you you won't be sorry you bought an Optima!!!!!
To Replacement Battery
