Blower motor?
Old Oct 23, 2004 | 11:56 AM
MostWanted's Avatar
MostWanted
Default Blower motor?
I noticed yesterday that when my AC was on...there was a buzzing noise that was louder when the AC was on high (10) and less louder when it was on low (below 10). Does this sound like a blower motor going bad? If not...what is it? If so...how hard is it to replace it? Thanks!
Old Oct 23, 2004 | 02:01 PM
bogus's Avatar
bogus
it might be, but it could also be debris inside the fan box.
I know the sound of a dying blower motor, it's more of a death rattle than a low buzz...
I will need to check my helms manual as for repair, I have never had to get into mine... but I THINK it's under the hood. hm... I will check....
Old Oct 23, 2004 | 09:06 PM
SunCr's Avatar
SunCr
Blower is on the right side of the firewall (engine side), next to the right fender. Make sure the cooling hose hasn't fallen off. It's a rubber tube from the left side of the housing to the motor. Otherwise, just unbolt the blower motor from the Evaporator housing. It's a probably a leaf or some other debris. You can jumper it once it's out to see if it's coming from the squirrel cage; doubt it's the motor, but you never know.
Old Oct 24, 2004 | 02:43 AM
MostWanted's Avatar
MostWanted
Thank! I'll try to fix it tomorrow.
To Blower motor?
