Hesitation @ WOT ??????
Old Jul 21, 2001 | 01:04 PM
Derf's Avatar
Derf
Having a hesitation when I hit WOT from standstill? She takes off ok, then hesitates then takes off. She’s an 86 vert, auto trans, stock except for flowmasters. New MAF, plugs (rapidfire), distributor cap, rotor, air cleaner, fuel filter, power relay and burnoff relay. Running great except for the hesitation. Any ideas??? Thanks
Old Jul 21, 2001 | 02:24 PM
Redmenace's Avatar
Redmenace
There probably could be several different things that cause this but I had a similar problem and it was caused by excessive knock retard. I was getting the knock retard because I had improperly set the initial timing without disconnecting the distributor advance bypass wire. An Autoxray is a nice tool for diagnosing these types of driveability problems.
Old Jul 21, 2001 | 04:09 PM
85WHITEZ51's Avatar
85WHITEZ51
My 85 does the same thing. Mine feels like it is having a hard time getting the fuel from the tank to the onjectors so I am replacing the fuel pump this weekend. I will try and let you know if that cures the problem. I say try because I don't know exactaly when I will attemp this. Alread have the part, just dreading the procedure.
P.S. my 85 has 155K miles on it so a new pump would be a good idea anyway
Old Jul 21, 2001 | 07:27 PM
85WHITEZ51's Avatar
85WHITEZ51
As I said, I will let you know what happened. Basically NO MORE HESITATION finally. As you can see of the time between the two post it was a very easy job to do. I actually changed my 02 sensor at the same time also. That could have made a difference also due to the fact that when it came out with 155K miles on it it was looking like a piece of chalk. Hope this helps you out a little bit.
By the way, a new pump and sock cost me $80 for a direct AC delco replacement and took about 1 hour to change. Good luck.
To Hesitation @ WOT ??????
