Knock sensor....
I get a code 43 very intermittant... I'm assuming it's retarding my timing, because I seem to lose power when it shows up.
I do not hear knocking or pinging. The engine sounds perfectly normal... cleaned the sensor and the electical connection going to it...
What happens if you just disconnect the knock sensor?
-JRC-
We got tired of constantly pulling the cable and installed this beauty for just that purpose.
suggestions for my question?
counts. Do this by creating a situation where is CAN'T knock,
and monitor for counts. In my case I got counts, revving it in neutral,
with a load of 91 octane gas (best we can get here) and the base
timing set to zero. There is no way a 9:1 engine can be ping under
those conditions. As a result, I have disconnected my knock sensor
and I rely on my ears to detect knock, just like the good old days.
Other cures are, actually finding and eliminating the source of the noise
causing the false counts, and/or changing to a better ESC module as
outlined it the Tech Tips section.
If the counts are TRUE knock, you need to find the cause and
eliminate that.
That will get you started (finished?)
RACE ON!!!
Your problem is due to a problem in the knock detection circuit that should be corrected. This can be due to a wiring problem, or a faulty knock sensor or, on '85-'89 L98s, a faulty ESC module.
As a first step verify that the connector hasn't fallen off the knock sensor.
What year car do you have???
BTW, to reset from limp home mode, just turn the engine off and restart it. It shouldn't recheck the knock sensor till after you are on the highway again.
The easiest way to reset trouble codes with an OBD-I system is to open the connector in the single Orn wire comming off the battery + terminal. This removes power only from the ECM so you can reset codes without losing all your other presets.
Mine's an 85, i recently removed the knock sensor cleaned it and cleaned the electrical connections and reconnected the thing, my book points to the knock sensor as being next to the starter on the passenger side, pull the sensor and watch the coolant flow- just to make sure I have the right sensor...
I'm not really quite sure what 'limp home mode' is, but that's not really important..
So see if I understand the replacement procedure. the only things that can set off a code 43, are the sensor itself, the ESC, or the wiring between, correct? Are there any points in the wiring I need to look for?
What would you recommend I replace first?
I meant that i've never experienced this, so it's not imperative to my immediate question...
If not look to the work you did on it as the cause of the problem. So check the integrity of the connecton to the knock sensor. if it it ok, check the ECM/IGN fuse; if ok, proceed below.
With the engine idling test voltage on the Blk wire from the ESC module and verify it is under 6Vdc; if not there is a faulty connection to ECM B7.
If under 6Vdc stop the engine and again check the voltage on the Blk wire; if over 6Vdc replace the ESC module (see my site for P/N).
You can test the knock sensor by rapping on the exhaust manifold or the block near the sensor to see if a signal is detected on the Blk wire from the ESC module.
And, yes, it does sound as though you indeed pulled the knock sensor as it penetrates into the coolant.
BTW, the ECM tests the knock sensor when the engine is under load, such as at WOT, and coolant temp is over 205deg F.
In there I point out that I have begin to isolate my light to the place I normally buy gas. If I am on the road or buy locally at another station I have never had the light only at one station.
I believe the sensor is doing just what it is supposed to do. It is telling me that for some reason it's not happy with the gas from that station.
counts.
RACE ON!!!
