Transmission fluid types
Old Jul 21, 2001 | 07:19 PM
GlobalGreg's Avatar
GlobalGreg
I need to add a little fluid to my tranny, the manual says to use Dexron IIE. All I could find at Autozone that resembled that was Dexron III by Aamco. Can I use Dexron III? If not, where can I find Dexron IIE.
Old Jul 21, 2001 | 11:17 PM
Short Timer II's Avatar
Short Timer II
Yes, you can use Dextron III in place of Dextron IIE. I just finished working on my car today. I dropped the tranny oil pan and changed the fluid and filter assembly. I used Quaker State Dextron III @ $1.59 per quart. It took just a tick under five quarts.
Old Jul 21, 2001 | 11:22 PM
GlobalGreg's Avatar
GlobalGreg
Thanks.
Old Jul 22, 2001 | 05:31 PM
GlockLT4's Avatar
GlockLT4
Just did the same thing to my blazer. I used about 5 quarts as well. The dipstick says Dexron IIE, but Dexron III is backwards compatible with it.
BTW.. that was a COMPLETE mess ..
To Transmission fluid types
