big brake
Old Oct 24, 2004 | 07:23 AM
10-35 vette's Avatar
10-35 vette
Default big brake
how munch are big brake kits.
Old Oct 24, 2004 | 08:54 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Originally Posted by 10-35 vette
how munch
Are you hungry?
Old Oct 24, 2004 | 10:49 AM
LD85's Avatar
LD85
http://www.superchevyperformance.com.../c4brakes.html
Old Oct 24, 2004 | 06:58 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
If you are talking about C5 front brake conversion, you should be able to do it for less than $500
Ed Salinas (member here) sells the caliper brackets. new c5 calipers are arond $ 90, rotors are around $ 60 and pads around $ 110
what's that add up to?
You may need wheels though! Y2k wheels work fine, I think Zr1 do as well
Jack
Old Oct 24, 2004 | 08:05 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Depends on what you consider big. I'm putting a 6-piston caliper with 13x1.25" rotors on up front.
Old Oct 24, 2004 | 08:20 PM
vader86's Avatar
vader86
If we're talking Brembo, Baer, Wilwood: one arm+one leg.
C5 brake setups go new at $700 for everything, slightly used under $500.
Old Oct 25, 2004 | 02:13 AM
BAM92's Avatar
BAM92
Or just look for a used 95-96 or ZR1 setup with J55's and 13" rotors for usually less than 200.
Old Oct 25, 2004 | 01:15 PM
10-35 vette
Jack How Do I Get A Hold Of This Fellow?
Old Oct 25, 2004 | 09:39 PM
CentralCoaster
asalinas2@***.net
To big brake
