Head Studs
Old Oct 25, 2004 | 07:56 AM
IBEAM700's Avatar
IBEAM700
From: Looks like I picked the wrong week to stop sniffin glue Orlando
Default Head Studs
I’ve read if head studs are used there could be a possible clearance issues when removing the heads with the engine in the car. Does anyone know if they’ll clear the accessories surrounding the heads?
Old Oct 25, 2004 | 08:27 AM
comp's Avatar
comp
i would think the mastercyl. may
Old Oct 25, 2004 | 08:35 AM
IBEAM700's Avatar
IBEAM700
That’s what I was thinking. I believe the passenger side is good with the exception of the A/C accumulator box, and the M/C on the driver’s side.
Hopefully someone out there can tell me for sure because they’ve tried it
Seems like im always the Pioneer.
Old Oct 25, 2004 | 08:51 AM
LPDesRoche's Avatar
LPDesRoche
Not sure what engine you have, but on a L98 the heads will come off fine with head studs. As for LT1 I haven't a clue.
Old Oct 25, 2004 | 09:00 AM
IBEAM700's Avatar
IBEAM700
That’s what I need to know right there…. L98 is what I have.
I have to replace the intake manifold gasket due to an oil leak, and while im there I might as well pull the heads and install new valve springs, Teflon seals, and CC roller rockers.
Old Oct 25, 2004 | 11:51 AM
CFI-EFI's Avatar
CFI-EFI
No need to pull the heads for that.
RACE ON!!!
Old Oct 25, 2004 | 12:06 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
All those operations can be done easily with heads on the engine.
Indeed I wouldn't pull the heads unless you have a problem with them or want to have them worked.
BTW, what year Vette??
Old Oct 25, 2004 | 12:50 PM
IBEAM700's Avatar
IBEAM700
I agree that all these changes could be made with the heads still on the car, but since im pulling the intake anyway its not really that much more work to pull the heads.
I do need some input on valve springs. Id like a nice solid valve spring that’ll work with 1.6’s and stand up to the test of time. If I need to have the spring seats cut to fit a larger diameter spring, that’s fine.
Old Oct 25, 2004 | 01:35 PM
65Z01's Avatar
65Z01
I used Comp. Cams #981 springs with the 1.6:1 ProMags on my '88 L98 with stock cam. I shimmed the springs (CC has a variety shim kit) to about 110lbs at the seat.
What year L98 do you have?
BTW, I too thought of how close I was to the heads when I had the intake and valve covers off. But that would have been more "fun" than I was ready for at the time.
Old Oct 26, 2004 | 10:21 AM
IBEAM700's Avatar
IBEAM700
I have a 1990, probably the same motor as your 88.
Did you have to cut the seats for the new springs?
Old Oct 26, 2004 | 09:02 PM
pablocruise's Avatar
pablocruise
I use ARP studs on my L98. I was not able to get my AFR heads on and off with all the studs threaded. It only requires the removal of a few rear studs. They are threaded into the block with an allen wrench so really it is a non-issue.
The thing I had a PITA with was coolant oozing past the stud threads in the block. I tried different kinds of thread sealer with no luck. Finally what did the trick was using a combo of wrapping the stud's threads with the teflon tape used in plumbing and then coating them with the white paste teflon liquid.
Old Oct 27, 2004 | 09:46 AM
LPDesRoche's Avatar
LPDesRoche
A few of my friends had that same problem(leaking). We solved it by coating the stud threads(end that goes in the block) with the thick black RTV. The kind used for rear ends, it works great for that. I have been doing it that way for years with no problems. Studs were designed for use in blocks that have blind tapped holes not ones that lead into the water jacket passages. None of the ARP sealants seemed to get them to stop leaking even after lengthy conversations with ARP reps. FWIW
Lee
To Head Studs
