clutch/tranny question on the ruby
I've been having some problems getting it to go into gear first thing in the morning, and when it's going into gear stiff it seems to roll when you release the clutch but don't press the gas
Today he said that happened and when he pushed the clutch down it was mush. He thinks it might be the clutch spring but then his dad told him it doesn't HAVE a spring but is hydraulic.Thanks all the experts!!!
FYI for those who helped on my 4+3 question, the OD seems to be working now, WEIRD!
If it were mine, I would replace the master, slave and line. Bleed the heck out of it, and only use GM hydraulic clutch fluid or it will squeak like crazy.
Fix this soon or damage to the ZF can occur. The classic symptom is trying to get it into reverse first thing in the morning or when cool, if the gears grind or it feels notchy you have the problem.
Good Luck,
Pete
BTW, it always seems that the vette's seem to have problems after a hubby drive. hmmmmmmm.
Pete can you give me a ballpark on how much this will cost? Will our joint tax return check cover it??Mojo, thanks, I'm not at home and he doesn't nee to drive it, he was just going to for fun.
