3rd break light
Old Jul 24, 2001 | 08:24 AM
CJ454's Avatar
CJ454
Cruise-In II Veteran
OK my 3rd light will not work. I changed the bulb and no luck. All the others work and the fuses are OK.I am guessing all are on the same fuse. #21 20A
Any thoughts on what to check next? Bad socket?
Thanx
CJ
Old Jul 24, 2001 | 08:45 AM
Ramjet's Avatar
Ramjet
I had the same thing on my '92. I tried changing the bulds, I even checked the wires. Turned out it was the switch on the back of the brake pedal. Picked one up at Auto Zone for about $4.00.
Old Jul 24, 2001 | 09:39 AM
CJ454's Avatar
CJ454
Thanx but the other lights work OK just the center one is notworking.
Old Jul 24, 2001 | 10:54 AM
Ramjet's Avatar
Ramjet
Right.. That was the only light that did not work on mine. The center brake light. I changed the switch and all's well now...
Roger
Old Jul 24, 2001 | 11:01 AM
Terry's Avatar
Terry
There are actually two different switch's. one for the 3'd light and one for the rear brake lights. I had a case where my rear brake lights were blinking when I would go down a bumpy road but not the third light! I just bent the pad a slight amount and it took care of it!
Old Jul 24, 2001 | 01:39 PM
CJ454's Avatar
CJ454
Is the switch easy to get to and do you know the part # of it.
I was not awair there would be 2 switches. Why do they do that?
To 3rd break light
