How's this combo sound for basic mods?
Old Jul 24, 2001 | 11:00 AM
Springer's LT4's Avatar
Springer's LT4
Cruise-In III Veteran
After reading through archives for several days, I've come up with a list of stuff I'd like to do to my 86 and have a couple questions about items I'm still not sure on.
The car is an 86, 70K miles, auto, all original.
K&N air filter
Open air cleaner lid up.
160 or 180 deg Tstat. (Live in central FL)
Switch or chip to turn fan on sooner.
Replacement mufflers or elims.
TPI air foil
TPS performance switch
Spark plug filing
TB bypass
Any thoughts on whether or not this should work well together?
What I'm still unsure about is the use of an adjustable fuel regulator, possible ram air system and the mufflers vs cat-back system vs elims?
We have no emissions testing here, so I can get away with pretty much any exhust mod, but I'm limited on the work I can do on my own due to living in an apartment complex.
Thanks for any thoughts on this.. this forum rocks!
Old Jul 24, 2001 | 11:54 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Those sound like a good general start. Do you have an L98 or LT1?
Check out my site for some things that work with an L98. You've got mail in case you want to go further with an L98.
Old Jul 24, 2001 | 12:03 PM
89C4L98's Avatar
89C4L98
Yup.. All good cheap mods. Except the throttle performance switch. I have heard bad bad things like it does nothing but throw codes etc etc. Spend the 100 bucks on a air pump eliminator will give you more hp and clean up the engine area.
Old Jul 24, 2001 | 12:14 PM
notbob's Avatar
notbob
I've got an '88 I've been building my list of small mods to do to it also.
Where can I get that AIR pump eliminator at?
Old Jul 24, 2001 | 03:15 PM
Springer's LT4
Does anyone have any input on an adjustable fuel regulator and ram air.. Would they be worth it with these mods?
Old Jul 24, 2001 | 04:34 PM
ROADAPPLE's Avatar
ROADAPPLE
The adj. fuel pressure reg. is a tuning tool, not a performance part. It allows you to tune the fuel delivery, you'll need a fuel pressure guage and some strip runs for it to help. I got the Cold Air filter housing (filter turned 180 deg.). Any thing you can do to cool the incomming air will help your 1/4 mile times. Expeciley (sp)here in Fl. I live in Winter Park.
DWS
To How's this combo sound for basic mods?
