Overheating Problem
Old Oct 26, 2004 | 03:07 PM
1fast91's Avatar
1fast91
Default Overheating Problem
I Have A Cooling Problem, Everytime I Start The Car And Go It Over Heats. I Then Turn It Off And Right Back On And It Runs And Cools Fine. This Has Happen To Me Three Times. I Just Replaced The Radiator About A Thousand Miles Ago And The Thermostat About 2,ooo Ago. Does Anybody Know How To Fix This?
Old Oct 26, 2004 | 03:14 PM
bogus's Avatar
bogus
air? bad t-stat? bad temp sender?
Old Oct 26, 2004 | 03:15 PM
mikey whipreck's Avatar
mikey whipreck
That usta happen to me in my daily driver cavalier... What was really odd was, I'd pull to the side of the road and put it in park, and the temp seemed to drop... Sometimes I'd hafta to shut it down and restart it, and that seemed to (temporarily) fix the overheating...
I replaced the radiator, hoses, and t-stat...
I'm sorry, but I dont think you wanna know how my story ended
Old Oct 26, 2004 | 05:14 PM
rws.1's Avatar
rws.1
Describe what you mean by overheats....
The coolant temperature runs up to XXX degrees?
The rad boils over?
C4's run hot, what we think is normal, you may think is overheating....
Old Oct 26, 2004 | 05:55 PM
aklim's Avatar
aklim
Get a scantool and see wht the ECM is reading. That way you will get a better idea if it is the gauge or the real overheating that you are seeing.
Old Oct 26, 2004 | 07:01 PM
CFI-EFI's Avatar
CFI-EFI
The way this is written, it doesn't make sense. It takes time for things to heat up, and it takes time for them to cool off. Is there a time line, you've left out, or is it just a gauge problem?
RACE ON!!!
To Overheating Problem
