brake rotor
Old Jul 24, 2001 | 09:20 PM
df5152's Avatar
df5152
Does anyone know of an after market rotor assembly, aluminum hat with bolt on disk, that that can be used with the stock GS calipers.
Dan
Old Jul 25, 2001 | 12:51 AM
MarkBychowski's Avatar
MarkBychowski
I have a setup like that from DRM (Doug Rippie Motorsports www.dougrippie.com ). It's an aluminum hat with a Coleman 13"X1.25" slotted rotor. A couple things, though:
1) not cheap. It was something like $325 per rotor.
2) Since the rotors are thicker than stock, you have to get shortened pistons for your calipers. Swapping the pistons is pretty easy if you're familiar with working on brakes.
3) DRM is sometimes not great at processing orders quickly. You can also check with Exotic Motorsports ( www.exoticmuscke.com )-- they carry a similar setup.
