Toasted camshaft...
Old Jul 24, 2001 | 10:42 PM
SCALF's Avatar
SCALF
Cruise-In I Veteran
Cruise-In II Veteran
in my '84. Comp Cams XE 256. #3 intake lobe just wiped clean. Comp is standing behind it with a replacement.
CC is getting slammed pretty hard on another board. Just wanted to check on this board for experiences and opinions
Have already ordered another custom grind...
Old Jul 24, 2001 | 10:44 PM
BBA's Avatar
BBA
Many causes, one weak valve spring, insufficient lube on break in, lifter stuck in bore ( won't rotate ), re-use of old lifters, over revving engine to induce valve float...
See, there are lots of reasons. At least you get a second chance to make sure it's right.
