gears or bolt-ons???
Old Jul 24, 2001 | 11:02 PM
whiteLT1's Avatar
whiteLT1
I have 92 LT1 6-speed. Should I put gears in or go with bolt-ons(Ram-air, chip, MSD)???I already have flowmasters, 160 thermo, throttle body bypass, & K&N with open air lid. Thanks
Old Jul 24, 2001 | 11:04 PM
TIMSPEED's Avatar
TIMSPEED
put in a set of 3.73 gears(possibly even 4.10's) and then put a 3000rpm stall converter in, and you'll be SET! For the price, the gears will give you the absolute most bang for your buck for the LT1.
Old Jul 27, 2001 | 01:40 AM
Mo_Bandy's Avatar
Mo_Bandy
I agree with timspeed...
Best bang fer the buck! MOGEARS...heh with your 6 speed I'd say at least 3.73 's
Mo
Old Jul 27, 2001 | 03:05 AM
GM_96LT4's Avatar
GM_96LT4
White,
Get the gears....
They will definitely give you the SOTP feel....
I have the 4.10's and just can't believe how fast you can go through the gears..
Good Luck,
Glenn
Old Jul 27, 2001 | 03:06 AM
Dean McManis's Avatar
Dean McManis
I've got stock (for 6sp) 3.45 gears, and I'm going to 4.10s next week.
Right now 5th and 6th gears are both overdrive anyway, and the engine is asleep at 1600RPM on the freeway.
With the 4.10s I'm hoping to have the Vette pull better in every gear. It should be quicker in the 1/4 mile, auto-X courses, and on the street.
Gears offer a pretty good bang for the buck, but you want to make sure that you get them swapped out by rear-end rebuilding pros.
The only other downsides of adding gears are lower fuel economy, losing traction from a stop more easily, and losing some top-end speed. It's a worthy trade-off for me for the extra potential zip.
-Dean.
Old Jul 27, 2001 | 04:21 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Originally Posted by TIMSPEED:
[B
[/B][/color]
The person who posted says theres a 6 speed so theres no 3,000 stall converter to be added..however, for the automatic cars, a higher stall and gears seems to be the best upgrades for a stock engine.
I hope to get a better converter myself someday with my automatic.
Money talks eh?
[img]http]//www.corvetteforum.cc/ubb/smile.gif[/img]
Old Jul 27, 2001 | 08:47 AM
nickd's Avatar
nickd
[B
the gears will give you the absolute most bang for your buck for the LT1.[/B][/color]
I agree, go with the gears!
These were my times:
2.59 gear
160° Tstat & fans reprogrammed, BPP Vortex Rammer
13.823 @101.50 60': 2.037
13.942 @100.21 60': 2.083
13.938 @99.61 60': 2.144
3.54 gear
Same mods above & Muff elims
13.418 @104.66 60': 2.141
13.315 @105.20 60': 2.051
13.258 @105.91 60'] 2.051
Old Jul 27, 2001 | 05:12 PM
Arisa's Avatar
Arisa
Put some 4.10's in the tail. Just did it! They've been in three days now. I was out driving (read playing) last night. I can't keep from bumping the limiter in 1st, 2nd, or 3rd right now. Yea it revs that quick. It will just take some getting use to on my part. Call Al Kindler he can get you a set of dana gears for $285 or so shipped. Lots of people say they (the 4.10's) whine. Mine make no more noise than the factory 3.45's
You will have to work on the speedo though. In your case I would get carputing's LT1 edit software. It is $250 if I remember correctly. That way you can screw with the other parameters of the car if you ever want/need to.
Neal
Old Jul 28, 2001 | 12:07 AM
GUMPA's Avatar
GUMPA
Gears........
Old Jul 28, 2001 | 01:34 PM
honas's Avatar
honas
Or maybe........You Guessed it! Nitrous Oxide! For about $500.00 you can get your car real near the 11's with NO driveability or reliability problems.
Old Jul 29, 2001 | 01:07 AM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Old Jul 29, 2001 | 01:13 AM
corvette dude's Avatar
corvette dude
Whats a good estimate of the cost for material and labor to have a set of 3.45's swapped out of my car and have 4.10's installed.
What would be my gains?
Old Jul 29, 2001 | 04:00 AM
Dean McManis
Honas,
$500 to get near the 11's is salesman's talk.
First off, if you want to make the N20 setup reliable you should get the safety goodies like a window switch, fuel pressure sensors, WOT switch, etc.. which puts it at around $1000+ installed. And 100HP shot takes about 0.6 seconds off a 1/4 mile time, adding 4MPH to the trap speeds. If you go over 100 shot then you need to retard the timing, and adding 150+HP can start messing with other stock drivetrain components.
So even though I'm glad that I added the N20 (it's a kick), I could probably have made the similar improvements just learning how to launch the car better.
Corvette Dude,
So far I bought the 4.10 gears from Al Kindler for under $300, and my friend pulling the differential out and putting it back should be about $150, and the actual gear swap will be another $150. So it should be around $600+ total, costing a bit more if you have a shop do the full swap.
I'm hoping to gain about 0.4sec and 3+MPH in the 1/4 with my new Corsa cat back and the 4.10 gears.
I'm looking forward to getting to the track again after I get it all back together to see how much better it performs.
-Dean.
Old Jul 29, 2001 | 05:57 PM
whiteLT1's Avatar
whiteLT1
How can I get in touch with AL Kindler???
To gears or bolt-ons???
