Popping noise in front end
Old Jul 25, 2001 | 10:39 AM
apollo30346's Avatar
apollo30346
I have just started hearing a popping noise in my front end... Any ideas on what this would be...I am thinking maybe a tie rod end or something..... What do you guys think?
Pete
Old Jul 25, 2001 | 10:47 AM
JonM's Avatar
JonM
Perhaps the Rack and Pinion steering or the power steering pump? Open the hood and have someone move the wheel for you.
Old Jul 25, 2001 | 03:13 PM
bill mcdonald's Avatar
bill mcdonald
Pete
[/color]
Can you tell us more about it?
Does it only happen when turning? Going over bumps? going over bumps and turning, going slow/fast etc...?
Old Jul 25, 2001 | 03:59 PM
corvette90's Avatar
corvette90
Check your swaybar connection if it is loose
.....naybe it comes from there..
good luck
Old Jul 25, 2001 | 09:16 PM
Thud's Avatar
Thud
Mine made a popping sound when turning the steering wheel at low speeds (like pulling into the garage).
David-F tightened up a couple bolts on the p/s rack for me and the noise went away.
Old Jul 25, 2001 | 09:27 PM
Ramjet's Avatar
Ramjet
Just changed the shocks on my '92. did not get the lower bolts on the passenger side tight. Had a popping sound over any and all bumps. re-tightened the bolts, all gone...
Old Jul 25, 2001 | 11:44 PM
apollo30346
seems like it only happens at low speeds and turning... I will have to pay closer attention to... I don't know about the bumps.
Thanks to all
Old Jul 26, 2001 | 12:13 AM
Thud's Avatar
Thud
Thanks to all
[/color]
I just noticed you're from Atlanta too. Which part? If you're close to me (Roswell) I can take a listen and tell you if the noise you have is the same thing I had.
Old Jul 26, 2001 | 12:45 PM
apollo30346
Thud,
I just live down by Perimeter Mall. Where are you in Roswell? I used to live up there off Holcomb Bridge Rd? Maybe you could help me threw a few issues.....
I saw you were from Roswell last night too..
David has done all my work on the car since I have had it... Major items anyway...
Old Jul 26, 2001 | 01:52 PM
Thud's Avatar
Thud
Originally Posted by apollo30346:
[B
Thud,
[/B][/color]
I live off of highway 9 (roswell road) just south of where it crosses the river.
I see your zip code is in your nickname. [img]http]//www.corvetteforum.cc/ubb/smile.gif[/img]
I used to work in that zipcode-- you know where the GoldKist building is?
Old Jul 26, 2001 | 02:40 PM
bill mcdonald
hmm, My '90 made a pop when turning in parking lots, and going over speed bumps. David F told me to check the drivers side rack mount bolt. Sure enough it was loose, tightened it and the pop was gone. I think that is a 15mm bolt.
Old Jul 26, 2001 | 11:38 PM
apollo30346
thanks I will check for that and others over the weekend.
Thud,
not sure where the Goldkist bldg is...humm..
Where are you located at...?
Old Jul 30, 2001 | 10:51 AM
apollo30346
Ok,
I looked this weekend when I had a chance between the rain and still can't find. Anymore input would be great.
Old Aug 3, 2001 | 11:42 AM
apollo30346
Default Re: (apollo30346)
Thud,
If your still willing to take a listen to the pop...let me know...I still can't find..
Thanks for the help..
Pete
To Popping noise in front end
