My vette lives!!!!!
some have been following my post http://www.corvetteforum.cc/ubb/Foru...ML/010515.html
Well I bought a new Ignition Module since I could not find a convenient place to test mine near work. Anyway I got home installed it.. hit the key and the still would not run.. so I adjusted the dist. and Whan fired right up!!!!
I then disconnected the EST to set Base timing and I had turned the dist to just the right spot at 6deg advanced..
I don't know if the Module is bad but I need to get it tested to verify..
WOOHOO I am PUMPED!!!!!!! I have not been able to drive it since 7/5
Good to hear!!! Nothing better then having it fixed eh?
Maybe the distributor backed off or came a little loose(happened on a friends car) and that may have been the culprit, but hey you have a new module now anyways.
It always helps to have a spare one around too..I tend to try and keep a few spare peices around in case something goes wrong.
Very handy to have on a trip with ya away from home too.
