Power Antenna
Old Oct 28, 2004 | 04:10 PM
mikey whipreck's Avatar
mikey whipreck
Default Power Antenna
Is there anything to service with a stock unit on an '85 l98? Mine works fine, but it's sounds like its working alot harder than it should have to... Is there any spot to lubricate the setup?
Old Oct 28, 2004 | 05:28 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Other than making sure the mast is clean and working free, nothing I know of. If it pukes, The Last Detail has good prices on OEM replacements for all C4s.
Old Oct 28, 2004 | 05:43 PM
mikey whipreck
good to know, thanks
Old Oct 28, 2004 | 06:16 PM
VenkmanP's Avatar
VenkmanP
If you open it up, you can clean out all the old, dirty, dried out grease and regrease it.
Haven't opened the one on the vette, so I don't know what it looks like, but I've refurbished several others over the years. Putting them back together can be tricky.
Old Oct 29, 2004 | 03:21 AM
JCD's Avatar
JCD
I'd extend the thing and spray it with WD-40, but it's probably a bad idea.
To Power Antenna
