Fixed the rattle on my Ripper shifter...
Old Jul 27, 2001 | 10:33 AM
maduraj's Avatar
maduraj
And I didn't even do anything to it. Last weekend I changed the rear end fluid. I put Mobile 1 synthetic and I put the limited slip additive in there too. Today I finally took the car out, and the car seems to be running a lot nicer. Less noise from the rear end. And, my ripper shifter doesn't rattle any more. It used to drive me nuts, every time I was in 1st gear, and had the engine at more then 2k rpm's, the shifter rattle would overpower my stereo ... Don't know how it happened, but it sure made a difference.
Old Jul 27, 2001 | 10:50 AM
1991Z07's Avatar
1991Z07
I thought maybe you were going to say you replaced it with the Hurst shifter
Old Jul 27, 2001 | 10:55 AM
maduraj's Avatar
maduraj
I was thinking about replacing it. I might do it around winter time when I'll be changing the clutch.
Old Jul 27, 2001 | 11:12 AM
Nathan Plemons's Avatar
Nathan Plemons
Originally Posted by maduraj
I was thinking about replacing it. I might do it around winter time when I'll be changing the clutch.[/color]
Have you driven the hurst? I've found the Hurst Camaro shifter's to be junk, hardly better than stock. I'd be hard pressed to believe that their vette shifter is better than the B&M. Again, I haven't driven a Hurst vette, so I could be wrong, but my experience thus far with Hurst have not been pleasant ones.
Old Jul 27, 2001 | 11:24 AM
maduraj's Avatar
maduraj
<BLOCKQUOTE><font size="1" face="Verdana, Arial">quote:[/color]<HR><font face="Verdana, Arial" size="2">Have you driven the hurst? I've found the Hurst Camaro shifter's to be junk, hardly better than stock. I'd be hard pressed to believe that their vette shifter is better than the B&M. Again, I haven't driven a Hurst vette, so I could be wrong, but my experience thus far with Hurst have not been pleasant ones.
[/color][/QUOTE]
No, I haven't driven a vette with the hurst shifter. I like the ripper, but the thing I couldn't stand was the rattle. But for some reson, it seems like the synthetic gear oil in the diff. took the rattle away.
Old Jul 28, 2001 | 12:58 PM
zrchris's Avatar
zrchris
Nathan- I think we've been over this before. Why do you insist on comparing two entirely different transmissions? The T56 shifter is as different from the ZF as either is to a Muncie. As the testimonies in this post below show and as many will soon see, the Hurst is the superior shifter for this application:
http://www.corvetteforum.cc/ubb/Foru...ML/010435.html
Chris
To Fixed the rattle on my Ripper shifter...
