"Fast Idle Hang Up"
Old Oct 29, 2004 | 07:41 AM
bigjack's Avatar
bigjack
Default "Fast Idle Hang Up"
My recently assembled 400 c.i. (219 cam, afr, superram, headers) in an '85 has a problem idle. Every minute or so it jumps from the set idle (900 rpm) to about 1200 and then s-l-o-w-l-y drops back to normal. In driving ( 4 + 3) it will "cruise" w/o acc. pedal , ikn gear at about 1500 rpm and "hang up" in rpm between shift, then slowly drop back to the set idle. I've replaced the rusted IACV and set it & the TPS per specs.Timing per instructions at 6* . Pulling 17.5 " vacuum at 900 rpm. No codes have been set and check shows self-diagnostics working. Fellow tuners out there can you offer any help??? Thanks, Jack
