Adjusted my TV cable and . . .
Old Jul 29, 2001 | 01:55 PM
toejam's Avatar
toejam
. . . wooooooohooooooo! I thought this thing shifted like a monster before but now . . . dayum!
Anyone know how often the cable should be re-adjusted? It doesn't seem like a very robust clip holding everything in place. Of course it is very easy to adjust so maybe it doesn't matter.
What an easy way to pick up performance
Old Jul 29, 2001 | 02:17 PM
XtremeVette's Avatar
XtremeVette
Original Founding Member!
Cruise-In 1, 3, 9. 10 & 11 Veteran
Toejam....what did you do exactly?.....I am having mine looked at this weekend coming up....the car already often spins and chirps the tires going into 2nd and I have an automatic.....I like that a lot.....but often the car seems to rev a little too long......I think.....what is the procedure....buddy....thankx
Old Jul 29, 2001 | 02:25 PM
toejam's Avatar
toejam
The TV cable attaches to the throttle linkage at the throttlebody. Follow that cable back a few inches away (toward the passenger compartment) to a black, ummmmm, thingie fixed to the manifold that has a silver button in it. On the other side of the thingie (god I'm so technical) the cable continues but is captured/protected by a sleeve. So the main components are the silver cable attached to the throttle linkage, the black thingie with a button, and the sleeve/slide.
1. Engine not running
2. Push in button on black thingie - hold
3. Slide sleeve/slide away (toward passenger) from thingie until it stops.
4. Release button on thingie
5. Manually move throttle linkage to WOT
6. You are done
Pretty simple, although I admit that the results I know have are similar to what you describe as current. Good luck!
BTW, you would be amazed at how many "thingie's" I have on my engine
-Scott
Old Jul 29, 2001 | 04:29 PM
Raysur's Avatar
Raysur
I will do this today, thanks .
To Adjusted my TV cable and . . .
