cleaning injectors
Old Oct 30, 2004 | 10:06 AM
85blkrose's Avatar
85blkrose
Default cleaning injectors
should i or should i say am i able to clean my injectors and feul system
myself or should i have this done professionaly.any comments and
on this would be great.
thanks,
chris
Old Oct 30, 2004 | 10:32 AM
ToyC4's Avatar
ToyC4
St. Jude Donor '05
I'm a firm believer in Berryman's Chemtool B12 fuel system cleaner which is available at most parts stores (Autozone for sure). If the injectors need a little more help check out Cruzin Performance. This guy cleans the injectors with ultrasonic waves and then flow tests each injector, it's pretty cheap too just $12 per injector: http://www.cruzinperformance.com/fuelinj.html
Old Oct 30, 2004 | 10:42 AM
Wayne88's Avatar
Wayne88
I had mine cleaned professionally.
They ran the car on chemical cleaner for 20 minutes.
It made a big difference.
Old Oct 30, 2004 | 12:12 PM
Southern Comfort's Avatar
Southern Comfort
I had mine cleaned in the car professionally when I first got it over two years ago. Except for only a few exceptions I have been running Chevron Premium with techron ever since.
Still runs like new even with 168K on the clock.
Old Oct 30, 2004 | 10:11 PM
Sam Lam's Avatar
Sam Lam
I like the Chevron Textron FI cleaner! It is not the lowest cost, but it is good stuff! Just be careful using it in years 89 thru 91 due to these Vette years having Multec injectors.
SAM
Old Oct 31, 2004 | 06:27 AM
85blkrose's Avatar
85blkrose
thanks for the info guys. the block is comming apart so i think they will just go to cruzin performance for service
Old Oct 31, 2004 | 08:40 AM
ittlfly's Avatar
ittlfly
You will be 100% happy with Rich's work at Cruzin........he'll take the time to talk with you on the phone if you have any questions.
To cleaning injectors
