Pan Gasket Extras??
Old Oct 30, 2004 | 01:31 PM
white94vette's Avatar
white94vette
Default Pan Gasket Extras??
I just bought a Felpro gasket set for my 94LT-1 oil pan. Its the blue permatorque style and it came with two additional round rubber like gaskets. One I figure is for the oil filter adapter that must be removed to get the pan off, but the second one I have no idea about.
Any ideas?
Old Oct 30, 2004 | 02:02 PM
STL94LT1's Avatar
STL94LT1
The round gasket and O-ring are for the oil filter adapter.
Old Nov 10, 2004 | 02:22 PM
white94vette
Seems the kit actually comes with a selection of gastets for the same location. One is a o-ring type while the other is a flat type, both seem to fit the loaction, but the o-ring style seems to more closely fit the size of the original.
Thanks for the info
Old Nov 10, 2004 | 02:27 PM
STL94LT1's Avatar
STL94LT1
Your original flat gasket is probably stuck to the block. You need to use both the flat and 0-ring gaskets to avoid leaks.
To Pan Gasket Extras??
