I need fender flares!
Old Oct 30, 2004 | 02:52 PM
drumboytroy's Avatar
drumboytroy
Default I need fender flares!
I bought a set of the AFS ZR1 replica wheels for my 85 coupe.The rears are 11.5 inches wide with Goodyear 315's on them. While AFS claims that the offset is correct for my car the wheels and tires come out 1 inch past the outside of the fender. I don't like that. I do like the look of all that rubber under my car....it looks bad to the bone from any angle. I have had more compliments about the tires and wheels since I installed them. So with that said I have been all over the net looking for fiberglass fender flares to mould to my body before I have it painted in January. I have found the small Corvette flares that fit over the top of the tire. I don't care for those. I want a flare that will go all the way around the wheel well about two inches wide. Does anyone have any idea where I can find these for a Corvette? Thanks
Old Oct 30, 2004 | 03:03 PM
6spd's Avatar
6spd
if you want the same one's that are on the grand sport?? look in ecklers, or midamerica i have seen them.
Old Oct 30, 2004 | 03:34 PM
drumboytroy
Yes I have seen those and they are actually the ones I don't care for. I want the ones that come on down the bottom half of the body to the bottom of the wheel opening. Has anyone ever seen these for C4?
Old Oct 30, 2004 | 03:35 PM
6spd's Avatar
6spd
you got me on that one sorry.
Old Oct 30, 2004 | 06:03 PM
drumboytroy
Looks like I may have to settle for them any way. Maybe if I mould them into the body instead of them looking like they were just peeled and stuck to the fender. Thanks for the info man.
Old Oct 30, 2004 | 06:06 PM
BAM92's Avatar
BAM92
Didn't know that anybody made those wheels in 11.5's. The flairs you are thinking of are the import ones. Hard to find. There is a post talking of import vette pics around here with pics of it.
Old Oct 30, 2004 | 10:19 PM
TA's Avatar
TA
I'm gonna go out on a limb and guess that the wheels he has are 11". If you measure an 11" rim from edge to edge I think you'll get 11.5",
but ifI you measure from bead to bead (the correct way) you'll get 11"
Old Oct 30, 2004 | 10:57 PM
SBNova's Avatar
SBNova
Thats odd that they stick out. I too have an 85 with AFS 17x11 ZR1 style wheels and mine dont stick out at all. Maybe you got the wrong offset by accident?
Old Oct 30, 2004 | 11:21 PM
cv67's Avatar
cv67
St. Jude Donor '05
If you cant get the wheel situation straightened out, make your own flares, starting with a cut out template as a starting point. Its gonna cost money either way, and youll be staring at them a lot. might as well make them EXACTLY the way you want them
Old Oct 31, 2004 | 12:31 AM
Powerdrive's Avatar
Powerdrive
I wondetr if you got the right offset ,.......heres a pic of my 315'z on my 92 its maybe a 1/4 inch stickin out.......................screw flares they look like
Old Oct 31, 2004 | 12:49 AM
RonRed89's Avatar
RonRed89
The imports even had flares for the front too.
Ron
Old Oct 31, 2004 | 12:58 AM
Draven's Avatar
Draven
St. Jude Donor '14
Mine look like that, too.
-Joe
Old Oct 31, 2004 | 11:13 AM
redfast's Avatar
redfast
Mine fit 100% under the fender. They sent you the wrong offset it they stick out more than that pic thats posted.
If you want fenderflairs get some BUSHWACKER cut-out extenda flairs
Old Oct 31, 2004 | 11:23 AM
drumboytroy
-Joe
Thanks guys. That's exactly how far mine stick out when you look straight down on them like the pic you posted. I believe they are the right offset after seeing your pics and hearing others agree. I'm just not used to seeing a tire out past the car. Like I said, it looks agressive and the compliments keep comming. Maybe I'm making a big deal over nothing. Thanks again.
Old Oct 31, 2004 | 03:33 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
Could get the GS flares and have the body shop blend them in... I haven't seen this done before though.
Old Oct 31, 2004 | 08:30 PM
JasonL's Avatar
JasonL
I've seen a race car C4 with flared fenders; I think they cut the quarter panels and then molded new fiberglass. I'm sure that wasn't cheap.
BTW, the GS flares are part of the export flares. The export cars have little "extensions" so the flares continue below the side molding.
Old Nov 1, 2004 | 12:12 PM
1996man's Avatar
1996man
does anybody have pics of these import flares?
Old Nov 1, 2004 | 12:48 PM
scorp508's Avatar
scorp508
There should be a picture around somwehre of a yellow late C4 with all of the euro flares. The front ones, the rear ones and the special euro rear pieces that blend them into the fenders better.
Old Nov 1, 2004 | 02:50 PM
BAM92's Avatar
BAM92
http://www.mycorvette.de/index.html
To I need fender flares!
