Need Help!!! EXHAUST BRIGHT RED
more likely the timing is way off... otherwise it's running way lean.
'lean' causes very high exhaust gas temps.
How could 'excess air' combustion cause high EGTs.
I just don't believe it.
Exception, going from 9:1 to 14.7:1, maybe higher EGTs.
Perhaps this 'myth' came from some guy who works
on airplanes / aircooled Beettles / some other engine with inadaquate exhaust valves,,, and gets around
the problem by running 9:1 AF ratio.
(excess air, leaner than 14.7:1)
"This ratio is called stoichiometric, meaning that there is a perfect mixture of air and fuel to insure complete combustion. This also happens to be the perfect mixture to get the highest temperature of combustion, and therefore the highest exhaust gas temperature (EGT). "
BUT, as you indicated in your post, take the case of an engine under load. You want more like 12.5:1 to make the best power in a typical gasoline engine. Say under load you're running "LEANer than you should" at 14.7:1 (stoichiometric), you will have extremely hot exhaust gasses, and probably glowing headers, maybe even melted piston crowns.
Those of us pointing to a lean AF ratio are assuming the engine was recently under load. Also, he mentioned it was hard starting when hot which sounds typical of an extremely lean AF ratio.
Now, another topic, how do we get a gasoline engine to survive at WOT and 14.7:1 AF ratio so we're getting the most out of every molecule of gasoline? Hmmm....water injection....don't hear much about it here.
Lets assume that gasoline octane rating, is not the issue, also, spark timing can be adjusted to whatever
is thought 'best'.
Note, Flame speed is highest at 14.7:1.
I just don't get how you can have max power
at 13:1 (or so), and not max heat (which would imply
high EGTs).
Sounds like plugged cats..
Why would his timing be off??? Did the dist just lossen up on its own??? Also as far as it being lean, his engine would be toast by now if it was that lean. Its hard to even get an engine like this to intentionally go THAT lean.
Plugged cats dude.
Plugged cats dude.
Jake
