Brodix heads.....
Then there is more, 23* and 18* heads for a SB chevy. sigh which one to use???
I'm also using a mini-ram and the combo is good for around 540HP at the crank.
If not, the Brodix heads are much better suited on a large cube motor like the 420 mentioned above. The stock heads do EXTREMELY well ported out by a competent porter.
BTW, you would want the 23* head. 18* is a race head and is awesome for a deep wallet as you would have to get custom made headers, intake, computer, etc. Wel worth it if you have the money...
With those heads on a stock or close cube motor (even a 383/396) you would have no velocity in the air inkate charge resulting in POOR DRIVABILITY until you go the motor to 4000+ RPM. At 5000 RPM, it would probably start ripping your head off, but at that point, you have essentially built a race motor that has no place on the street.
$700 more will get you heads that will rip your head off down low, better gas mileage, great drivability even with a large cam, more HP than you can hook on the street, etc.
That would be my suggestion.
Now if you are going to do a max effort 420, the Brodix Track 1 heads would be a killer head!!!
Good Luck,
I can tell you, call Brodix. They will BUILD you a head that fits YOUR combo for the same price Summit will sell you a generic set for.
Other than that, the "Dragon-Slayer" Brodix head ( based on the 8FSH casting ) is probably the best smallblock street head in existance. I know they make more HP than almost any other manufacturer, the ports are designed with high velocity and a twist that really makes a lot of power.
The 10 series heads are usually designed for higher horsepower motors ( were talking 700 HP gran prix engines... all the sbc gran prix motors use Brodix 10 series ).
If you can tell...I like Brodix, I had nothing but GOOD experiences with Brodix and the heads they built for me.
I think Brodix is a little less big into advertisement than the other brands, but they are the real deal.
Yes I do agree with you BBA the track one is not the only head! I'm still looking at there site. The dragon slayer...... humm intresting........
[B
To make you feel better - I don't know squat about Brodix heads. Wouldn't have clue one and not a single bad thing to say about them.
Course then - it ain't over yet.
Denny - 398ci LT4 Collectors Edition.[/B][/color]
[img]http]//www.corvetteforum.cc/ubb/smile.gif[/img] I am ready!!!http://www.brodix.com
Imagine that
Also, here are the Dragon Slayer heads:
http://www.brodix.com/Catalog/Heads/...fsh_pkg-1.html
I can tell you...they make crazy horsepower for a 350-383 and a nice roller cam. Don't even think the ports are too small...because these bad boys work!
[This message has been edited by BBA (edited 08-01-2001).]
