Who thinks I can get it done?
Old Jul 30, 2001 | 02:20 PM
scorp508's Avatar
scorp508
http://www.corvetteforum.cc/ubb/Forum7/HTML/006510.html
Old Jul 30, 2001 | 02:40 PM
Guest
Guest
Posts: n/a
I think it can be done but your going to need a lot of help.
I'd give you a hand Scorp if I had the Knowledge, but I'm pretty much useless.
Maybe some of the N.E. guys could give you a hand. I'd love to watch and learn a thing or two!
Mark
Old Jul 30, 2001 | 03:10 PM
Nathan Plemons's Avatar
Nathan Plemons
I don't know about the L98 engine, but I know that my cam swap and such took a week and a half, but we didn't have the ideal working condiations.
We were working from like 10am-3pm and then from 10:30pm until we were about to fall asleep. Even then there were a few days we didn't work at all. My project also sucked because we had to drop the tranny, etc in order to raise the engine to get to the crank hub, to get the timing chain cover so we could finally get to the cam. I don't know if the L98 is that much of a PITA or not. At the point we were, heads wouldn't have taken but another day, assuming you have new heads that you are just going to bolt on.
If you have the ability to work on the car, only the car, and nothing but the car, I would say that you can EASILY do it in a week.
Old Jul 30, 2001 | 03:15 PM
MrJay's Avatar
MrJay
I would help you but just to far to go, and that weekend we have a race to go to, I bet you can get guys to help you that live closer.
Good luck.
Jay
Old Jul 30, 2001 | 03:20 PM
scorp508's Avatar
scorp508
Originally Posted by MrJay:
[B
[/B][/color]
Thanks, I appreciate it. There is no doubting that the MA guys are all willing to jump in and help me out. That part I'm not worried about, but there is only so much room for so many hands in the engine bay.
I think the heads/cam stuff can easily be tackled by myself and my father, the Superram might be when I call in the recruits who have already installed them a few times. [img]http]//www.corvetteforum.cc/ubb/biggrin.gif[/img]
Old Jul 30, 2001 | 03:29 PM
-=Jeff=-'s Avatar
-=Jeff=-
see my reply on the aftermarket page
Old Jul 30, 2001 | 03:34 PM
Fastguy's Avatar
Fastguy
St. Jude Donor '03-'05
Check my reply to that thread for accurate prediction of events.
Old Jul 30, 2001 | 03:40 PM
Dave's_88's Avatar
Dave's_88
If you think you can do it, GO FOR IT! This seems like a perfect opportunity.
1) Free car use for 1 week (no strings)
2) The desire to upgrade your vette
If you don't do it, you'll beat yourself for not trying.
-Dave
P.S. Make sure to double check your parts list prior to the "working week"...I was amazed by how many seals required gaskets.
Old Jul 30, 2001 | 04:18 PM
scorp508's Avatar
scorp508
Originally Posted by Fastguy:
[B
[/B][/color]
Very accurate! [img]http]//www.corvetteforum.cc/ubb/smile.gif[/img]
Old Jul 30, 2001 | 04:22 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Scrop, sounds ambitious, but then I just spent a week and a half doing the valve train. I suspect you will have some sleepless nights that second week, but could be a fun challange.
Old Jul 30, 2001 | 04:23 PM
J Z06's Avatar
J Z06
Good luck...and you'll be all smiles when it's done and tuned.
If the Super Ram DOES concern you.. it should. My mechanic and I had to get ball shaped allen wrenches to get a few of them back on last summer doing the EGR Valve(WHAT A WASTE OF TIME THAT WAS). If you ever need to call or ask... BUZZ ME.. ya have the #.
Old Jul 30, 2001 | 04:27 PM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
i think the timing is perfect, get some help from the guys and have at it
Old Jul 30, 2001 | 04:54 PM
olephart's Avatar
olephart
Not much downside if you don't make it on time.
All you need to do is get a Rent-A-Ricer for 2 days. That will carry you into the next weekend.
Make sure you get photos of U in the ricer .
Old Jul 30, 2001 | 09:13 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
I think you can do it.
Old Jul 30, 2001 | 09:17 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
Sorry Brian, No way.
Whenever your working against the clock you asking for problems.
Old Jul 30, 2001 | 11:36 PM
lowflyer's Avatar
lowflyer
Cruise-In I Veteran
Although I don't think rushing things like this on a tight schedule is a good idea, here is my $.02 from my recent motor rebuild experience:
You might want to get a Balancer INSTALLER. I don't think its a good idea to whack the balancer on with a big-ol hammer.
Also, Snap-on has this nifty thing that holds your flywheel while you tighten the bolts that will normally try to turn your motor.
Cam degree wheel and someone who can accurately use it.
Hows your rack and pinon? Does it get morning sickness? Good time to do it when the motor is out of the way. This also goes for lowering your front end. The spring pad nuts are easier to get to as well.
This is just off the top of my head, I'm sure I'll come up with more later Good luck.
Old Jul 31, 2001 | 12:29 AM
Thud's Avatar
Thud
Originally Posted by Nathan Plemons:
[B
We were working from like 10am-3pm and then from 10]30pm until we were about to fall asleep. Even then there were a few days we didn't work at all. My project also sucked because we had to drop the tranny, etc in order to raise the engine to get to the crank hub, to get the timing chain cover so we could finally get to the cam. I don't know if the L98 is that much of a PITA or not. At the point we were, heads wouldn't have taken but another day, assuming you have new heads that you are just going to bolt on.
[/B][/color]
How much different did the hot cam make?
Old Jul 31, 2001 | 10:27 PM
L98Terror's Avatar
L98Terror
W. Detroit Events Coordinator
Cruise-In VII Autocross Champ
Been there done that, and no I didn't finish
To Who thinks I can get it done?
